Go to Post The game is leaking? That can only mean... - GeeTwo [more]
Unread 11-02-2012, 13:02
walterbishop13 walterbishop13 is offline
FRC #4200
walterbishop13 is on a distinguished road
Unresponsive drive system
We had our robot working, then took it apart and rewired it. Now,
although we had the jaguars running earlier today, now they are not
... responsive although the yellow light is solid and lighting up. We have
reimaged the crio and uploaded the default code control program. The
jaguars will not make the motors move with joystick control or in
autonomous mode. What should we try next? any input would be greatly
appreciated.
RE: Drive system not working since last Thursday. We had two Jags controlling four CIM motors, it was working. But because of rules we now have one Jag per CIM motor, and now with four Jags the system is not working.
The Jaguars are correctly wired, and blink orange indicator light when not receiving signal and solid orange when intaking signal. When we run the drive program with Driver Station the motors do not respond, but the Jags show the solid orange indicator light.
Unread 11-02-2012, 14:27
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Unresponsive drive system
What language are you programming in? Do you have the PWMs plugged correctly into the digital sidecar and jags?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 11-02-2012, 18:26
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
So it appears that your jags are properly wired power and pwm wise... If you are saying that they stay a solid color when running deployed code. I suggest having your programmers take a look at their pwms referenced and make sure they are correct with the actually pwms on the robot.
Unread 11-02-2012, 18:32
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
A code snippet would be helpful.
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 11-02-2012, 20:05
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
What is the motor arrangement? Are the motors mechanically paired (such as two motors connected to one gear box)? If so, it's possible that when you added the second jag, the wiring could get reversed and drive the motors against each other. Then nothing would move (and the jag's would probably indicate over-current).
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 11-02-2012, 20:09
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
There are various default code templates and various programming languages for teams to use. Which particular one did you upload? (e.g. Labview tank, Java arcade)
Jaguars do not turn solid orange (manufacture specs say yellow, but it's anywhere from yellow to orange) when they receive signal, but when they receive a neutral signal. They will turn either orange/yellow, red, or green when they receive a signal (if the frequency of the signal is in the right range, you may also see the LED cut out).
I would follow keyreaper's suggestion just to check any inconsistencies, but I highly doubt that is the problem at hand here because if you are referencing the wrong PWM out ports, your Jaguars would not turn solid when you enable the robot.
If you can, revert your code to the version that worked with the 1 Jag per 2 cim configuration. Then connect two of your Jaguars as your Jaguars in that configuration were connected and see if anything runs.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
