Go to Post Stacking totes on end; Gives you extra height, alas; Topples with a sneeze. - BethMo [more]
Unread 11-02-2012, 20:17
Stonemotmot Stonemotmot is offline
FRC #0486
Stonemotmot is an unknown quantity at this point
Help with website
Hello, my team is working on the website and were trying to do some java script but could not get it to work could someone tell me what is wrong with this simple script.
<html>
<head>
</head>
<body>
<h1>Team #</h1>
<p id="demo"></p>
<button type="button" onclick="displayDate()">Display Date</button>
<script type="text/javascript">
var a =1;
function displayDate()
a=a+2;
if (a==1)
document.getElementById("demo").innerHTML="Hello";
else
document.getElementById("demo").innerHTML="GoodBye ";
</script>
</body>
</html>
Unread 11-02-2012, 22:01
HansJ's Avatar
HansJ HansJ is offline
AKA: Hans
FRC #3018 (Nordic Storm)
HansJ is on a distinguished road
Re: Help with website
Add a set of curly braces around the code you want in the function e.g.
var a =1;
	a=a+2;
	if (a==1)
	else
The if statement that changes the innerHTML was not being called when you clicked the button, only the addition part
Make sense?
2013 Lake Superior Excellence In Engineering Winner
2013 Lake Superior Dean's List Finalist
2013 10,000 Lakes Engineering Inspiration Winner
2013 Championship Creativity Award Winner
Unread 11-02-2012, 22:41
ianonavy ianonavy is offline
Programming Mentor/Alumnus
AKA: Ian Adam Naval
FRC #3120 (RoboKnights)
ianonavy is an unknown quantity at this point
First of all, you should ALWAYS begin your HTML files with a doctype.
<!DOCTYPE html
Your JavaScript should really be in a separate file that is linked in with something like this before the </body> tag:
<script type="text/javascript" src="js/index.js"></script>
with all your JavaScript being put in the file "index.js" in a "js" subdirectory.
Second of all, I made a little demonstration snippet using JSFiddle, which can be found here: http://jsfiddle.net/ianonavy/cfHpd/
I hope this helps. Continue to post if you have further questions.
Unread 12-02-2012, 15:16
FRC #0486
Thank you I understand what I did wrong. You were big helps.
