Go to Post "Only YOU can prevent G22 infractions." - Qbranch [more]
Unread 11-02-2012, 20:32
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Encoder Glitchy Issue, Help Needed
FYI, Issue resolved by moving the encoder processing code from Teleop.vi to Routine Task VI, where it should have been all along. I suppose lag associated with receiving DS packets knocked the timing off the encoder's calculations.
Why a single encoder always seemed to work okay, that will remain a mystery (maybe the amount of code processed pushed the Teleop VI beyond the Watchdog timer limit?)
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 11-02-2012, 20:51
Did you try reading the encoder count in TeleOP, and computing
(change in encoder count)/(elapsed time since previous encoder count was read) ?
That should be reasonably insensitive to variations in the timing of receipt of DS packets, no?
