Go to Post Remember guys, if your mentor wasn't there, odds are, you wouldn't be either. - Corey Balint [more]
Unread 11-02-2012, 20:51
Re: Encoder Glitchy Issue, Help Needed
Originally Posted by seg9585 View Post
FYI, Issue resolved by moving the encoder processing code from Teleop.vi to Routine Task VI, where it should have been all along. I suppose lag associated with receiving DS packets knocked the timing off the encoder's calculations.
Did you try reading the encoder count in TeleOP, and computing
(change in encoder count)/(elapsed time since previous encoder count was read) ?
That should be reasonably insensitive to variations in the timing of receipt of DS packets, no?
