Go to Post 50 years from now, the FRC will still be waiting and hoping for a water game. That's my prediction. - TheBoulderite [more]
  #31   Spotlight this post!
Unread 11-02-2012, 20:47
austin1743 austin1743 is offline
Head Programmer - Java
FRC #1743
austin1743 is an unknown quantity at this point
Re: Java to Crio Downloading Issues
i have 2 different ip address. one for the cRio and one set for the laptop.. should they be set to the same exact thing?
subnet is set just as it should be... the (255.255.255.0)
Team 1743
Head Programmer
  #32   Spotlight this post!
Unread 11-02-2012, 20:55
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
No, not the same thing, but on the same range, and make sure the cRIO's is 10.xx.yy.2
  #33   Spotlight this post!
Unread 11-02-2012, 21:29
FRC #1743
ok cool,
i have the cRio at 10.17.43.2
and the computer at 10.17.43.5 (i believe)
what is the correct range?
Team 1743
Head Programmer
  #34   Spotlight this post!
Unread 11-02-2012, 23:53
AKA: JD Russo
Yep, that looks right.
Check firewalls and what network device the driver station is using. Can you ping the CRIO?
  #35   Spotlight this post!
Unread 12-02-2012, 11:34
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
ok cool,
By range, he means the same IP subnet.
How IP subnets work is if you look at the IP address and subnet mask in binary, the 1s in the subnet mask mean that that bit of the address is part of the the network address, and 0s in the subnet mask mean that that bit of the address is part of the the node address. So, they are in the same subnet if all of the network bits in the IP address are the same.
So,
// pseudo-code
// Addresses in binary
cRIO   = 10.17.43.2   ; // 00001010.00010001.00101011.00000010
laptop = 10.17.42.5   ; // 00001010.00010001.00101011.00000101
netmask= 255.255.255.0; // 11111111.11111111.11111111.00000000
// binary and
cRIO_network = cRIO & netmask
laptop_network = laptop & netmask;
println(" > "+cRIO_network); println(" > "+laptop_netowork);
 > 00001010.00010001.00101011.00000000
println(" > "+(cRIO_network == laptop_network))
 > true
Without doing any binary math, though, if the subnet mask is all 255s and 0s, you can tell easily; 255 means that octet is network, and 0 means node. A mask of "255.255.255.0" means that your range is "10.17.42.*".
  #36   Spotlight this post!
Unread 13-02-2012, 15:43
FRC #1743
thanks alot guys for the help. The cRio wasn't imaging correctly because of an IP adress issue that is now fixed
now we have a cRio that receives code greatly
we are now at another problem.
when we activate tele-op mode our robot doesn't move. I also checked the driver dashboard and i am not getting any pwm input/ output when i move the controller... i know normally i should see the first 4 pwm ports moving when i move the controller. any suggestions?
Team 1743
Head Programmer
  #37   Spotlight this post!
Unread 13-02-2012, 19:06
AKA: JD Russo
Check in the driver station, click the SETUP tab, and look on the right hand side. Look under the tab labeled "Joystick Setup (drag to order)" and make sure at least one of those has a joystick under it. Then make sure it's in the right position. Those positions correspond to joystick values in the code. Press any button on the joystick, and the corresponding one should light up blue in that setup pane.
  #38   Spotlight this post!
Unread 13-02-2012, 20:16
FRC #1743
i will try that tomorrow,
i am looking through the code to make sure i have it working the way it should...
i used a tank drive which works great and the joysticks moves the robot... all but i need mecanum drive to work as we have mecanum wheels on the robot...
i am quite new to programming in general and im not sure i have it set right... i looked at another teams mecanum code and it seem to look very similar... i have attached our code to this message. if someone could take a look at it and let me know what im missing that would be great and amazing.
thanks for the helps guys.
Team 1743
Head Programmer
