Go to Post Thank you to all of the mentors, You ARE changing the future. - chellyzee93 [more]
Unread 11-02-2012, 22:06
xisybyl xisybyl is offline
FRC #3648
xisybyl is an unknown quantity at this point
Re: Cannot get Spike Relay example to work
Thanks, Alan for your reply and help. We are up now, but thought I'd close the loop.
It turned out we had two issues going on. The first was a "bad" cable btwn sidecar and cRIO module. Our repaired (due to mfg. defect) ribbon cable was not reliable. Very difficult to make a ribbon connector that large without proper tooling (a vise doesn't quite cut it). To make matters worse, neither of two round cables from previous years worked. (One of our mentors is having them checked at her company so we can understand why - do you?). The ultimate solution was to locate a completely new ribbon cable and use that. (This has been a solution to accelerometer issues elsewhere in Chief Delphi).
Second was getting the compressor and robot drive BOTH functioning. I ran a direct compressor reference wire from the begin VI to the Periodic (Timed Tasks) VI and located the compressor control VI there. (Later I discovered it was there already but was disabled.) Thanks for your comments on that. It took awhile for the solution to become clear.
As a final note, given that the compressor integration from example into the robot project was significantly different than most other examples I think it would help others if FRC added a note of clarification to the pneumatic examples.
