Go to Post Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time? - JVN [more]
Unread 11-02-2012, 19:00
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
How are you pushing down bridge?
We are design a bridge mechanism and seeing what other people are using and what kind of success they are having
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 11-02-2012, 19:21
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: How are you pushing down bridge?
We have an one inch 1/8" wall aluminum tubing arm with a little under 90 degree "bend" in it with a free wheel on the end being turned by a banebot(I think?). I'm can't contest to the success, but from what I've heard it works beautifully.
Academic Student (Forever)
Unread 11-02-2012, 19:25
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
Marysville 3484 is pushing the bridge down with their robot. We lift the robot into the air and put our omni wheels down to push the bridge down.
Unread 11-02-2012, 19:39
BOSS BOSS is offline
FRC #2883
BOSS is on a distinguished road
TEAM F.R.E.D is using an arm on a window motor with a wheel at the end, having issues trying to get it to reverse just get it to go forward. I am sure there should be a way to make a relay go forward and reverse or am I mistaken.
Unread 11-02-2012, 21:29
legogeek24's Avatar
legogeek24 legogeek24 is offline
AKA: Dirk
FRC #3562 (LiveWire)
legogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura about
@BOSS, I'm pretty sure relays are either on or off, with no direction. At least, I've never heard reversing a relay is possible.
@Johnny_5, how exactly are you accomplishing that? When you lift your robot in the air, aren't the bumper rules violated?
As far as my team, we're going to use our movable shooter/cannon to push the bridge down as we drive onto it.
4 year FIRST alumnus and current MIT Computer Science student
Mentor for LiveWire 3562 and The Arabian Knights 4928
"1...2...3562!!!"
Unread 11-02-2012, 21:35
CalTran's Avatar
MST Rolla Senior
How on earth does that work?
Unread 11-02-2012, 21:46
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
@Leogeek24 @BOSS:
I must assume you are using a Spike type thing, because then if so there most definitely is.
The relay (at least the spikes) Flip their output polarity when given that certain command. Someone correct me if Im wrong
http://www.wbrobotics.com/javadoc/ed...ibj/Relay.html
If you look at the relay.direction stuff, there is like kReverse and kForward or something along the lines of that.
What the..... Winning
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 11-02-2012, 22:08
FRC #2883
We are programming in Labview so the Kforward stuff is Greek to me and our programmers. we are using the Spike Relay to control the motor. Any one got stuff on Labview.
Unread 11-02-2012, 22:14
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Well, this may sound odd, but we are doing a wheelie and pushing it down the the front wheels...
"No, you can't use the Kinect to do pelvic thrusts."
Unread 11-02-2012, 22:18
dellagd's Avatar
AKA: Griffin D
Sorry no.
I mean this humorously, but me and the other main programmer are hard-core C++ & JAVA guys. LabVIEW makes at least us two shiver.
Unread 12-02-2012, 00:46
chi-town-biker chi-town-biker is offline
FRC #3135 (Robotic Colonels)
chi-town-biker is an unknown quantity at this point
Here's a great source of LabView code snippets including code for relays. http://team358.org/files/programming...2009-/LabVIEW/ Thanks Robotic Eagles.
Unread 12-02-2012, 00:57
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
my friend says his robot does this to didn't think it we be used by anyone else o.O
[R01-2]....Note:..... A Robot in a transitory state of crossing onto/off of a Bridge or Barrier is not considered to be on a flat floor.
yeah team update 2012-01-20
cole?
Unread 12-02-2012, 01:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
When it's on the bridge, it's in a transitory state...but when it is lifting up and is not yet on the bridge, it might be violating the rule?
We don't know if ours works yet, we have to put some weight on the bridge and try it. Or at least draw a Free Body Diagram, so we can figure out if it should work. It's just an arm that pops down in front of the robot at an angle, and we drive the robot into the bridge, and hopefully push the end of the bridge down as we move forward. It's pneumatically actuated.
Unread 12-02-2012, 01:36
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FORST Team 1296 is using a van door motor geared up a bit to push down an arm made with 1" square aluminum extrusion. The arm is 2-pronged, we are hoping a ball (on the bridge) might roll between the prongs and into the gatherer.
Unread 12-02-2012, 01:43
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Team 3992 is using a 12" stroke pneumatic cylinder to facilitate a 90 degree retraction and extension of an arm.
