Go to Post Never Underestimate the power of zip ties! - tonyargote [more]
Unread 09-02-2012, 18:22
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Allocating 1.8GB memory.... problem?
I seem to have an issue... Our logomotion code, recompiled for this year, boots, until it tries to allocate 1.8GB memory:
* Loading visa32.out: visa32
* Loading niserial.out: niserial
* Loading NiFpgaLv.out: NiFpgaLv
* Loading FRC_FPGA.out: FRC_FPGA
* Loading FRC_NetworkCommunication.out: FRC_NetworkCommunication
FRC_NetworkCommunication was compiled from SVN revision 2923
FPGA Hardware GUID: 0xA14C11BDE4BB64AEF6A86FC52A294CD9
FPGA Software GUID: 0xA14C11BDE4BB64AEF6A86FC52A294CD9
FPGA Hardware Version: 2012
FPGA Software Version: 2012
FPGA Hardware Revision: 1.6.4
FPGA Software Revision: 1.6.4
* Loading FRC_BlackJagBridgePlugin.out: FRC_BlackJagBridgePlugin
FRC_BlackJagBridgePlugin_5200 was compiled from SVN revision 72
* Loading FRC_UserProgram.out: FRC_UserProgram
...FRC_UserProgram failed to load.
Welcome to LabVIEW Real-Time 11.0rc14
task 0xddc4a0 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
task 0x11245b8 (FTP Server Connection Thread) deleted: errno=0 (0) status=0 (0)
-> * Loading debug.o: debug
Debugging is up, target server mounted at /tsfs
VxWorks
Copyright 1984-2006 Wind River Systems, Inc.
CPU: MPC5200 -- Wind River Lite5200 BSP.
Runtime Name: VxWorks
Runtime Version: 6.3
BSP version: 2.0/10
Created: May 27 2011, 11:02:24
ED&R Policy Mode: Deployed
WDB Comm Type: WDB_COMM_END
WDB: Ready.
* Loading nisysrpc.out: nisysrpc
* Loading NiRioRpc.out: NiRioRpc
* Loading nivissvc.out: nivissvc
* Loading nivision.out: nivision
NI-RIO Server 4.0.0b8 started successfully.
task 0xe2ffb8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
Duplicate symbol:"main" loading module FRC_UserProgram.out
WPILib was compiled from SVN revision 2993
task 0xddc440 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
0x111ce88 (FRC_RobotTask): memPartAlloc: block too big 1819043856 bytes (0x8 aligned) in partition 0x32d6b8
data access
Exception current instruction address: 0x000e6864
Machine Status Register: 0x0000b012
Data Access Register: 0x5a425443
Condition Register: 0x84000088
Data storage interrupt Register: 0x40000000
Task: 0x111ce88 "FRC_RobotTask"
0x111ce88 (FRC_RobotTask): task 0x111ce88 has had a failure and has been stopped.
0x111ce88 (FRC_RobotTask): fatal kernel task-level exception!
data access
Exception current instruction address: 0x00034b08
Data Access Register: 0xf0089cc8
Condition Register: 0x44444042
Task: 0x3efc80 "tNetTask"
0x3efc80 (tNetTask): task 0x3efc80 has had a failure and has been stopped.
0x3efc80 (tNetTask): fatal kernel task-level exception!
task 0xddbc60 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
0x111cf80 (FRC_RobotTask): memPartAlloc: block too big 1819043856 bytes (0x8 aligned) in partition 0x32d6b8
data access
Task: 0x111cf80 "FRC_RobotTask"
0x111cf80 (FRC_RobotTask): task 0x111cf80 has had a failure and has been stopped.
0x111cf80 (FRC_RobotTask): fatal kernel task-level exception!
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xe2f6f8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
task 0xddbb80 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
task 0x1113838 (FTP Server Connection Thread) deleted: errno=0 (0) status=0 (0)
VxWorks
BSP version: 2.0/10
WDB: Ready.
task 0xe2f898 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
task 0xddbd20 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
0x111cfc0 (FRC_RobotTask): memPartAlloc: block too big 1819043856 bytes (0x8 aligned) in partition 0x32d6b8
data access
Task: 0x111cfc0 "FRC_RobotTask"
0x111cfc0 (FRC_RobotTask): task 0x111cfc0 has had a failure and has been stopped.
0x111cfc0 (FRC_RobotTask): fatal kernel task-level exception!
data access
Any ideas?
Watchdog.Kill();
Unread 10-02-2012, 15:55
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Allocating 1.8GB memory.... problem?
Well, you should post your code so we know what exactly is allocating 2GB of memory.
Unread 10-02-2012, 18:34
byteit101's Avatar
our logomotion code, recompiled from last year: https://bitbucket.org/byteit101/logo/src
It worked for us perfectly at the competitions, so not sure why its failing this year....
Watchdog.Kill();
Unread 10-02-2012, 19:38
Hjelstrom's Avatar
Hjelstrom Hjelstrom is offline
FRC #0987 (High Rollers)
Hjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond repute
I looked over your code briefly and didn't see anything that looks like it would cause the problem. For one thing you don't do many (any?) manual memory/object allocations (so that rules out a lot of potential problems I was looking for).
I'd try putting a print in the first line of your robot's constructor and see if the crash happens before or after that. Assuming it happens before your print, then you'll probably have to start commenting member variables and their associated code out to figure out where the problem is. Nothing against ZomB but I'd try commenting that out first; maybe you need an updated version of it that is compatible with this year's WPI lib? Or your code is trying to talk to an older ZomB but you're linking in the new code? Just a guess.
Unread 11-02-2012, 15:59
byteit101's Avatar
ZomB I did remove, along with 99% of the code, just the joystick remainig, and it still crashed....
strange....
Watchdog.Kill();
Unread 11-02-2012, 21:20
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Minimal Test Case?
Edit: I mean, post it.
Unread 11-02-2012, 23:05
Hjelstrom's Avatar
strange....
Ok, did you do the print test? Is the crash is before or after your robot's constructor?
Unread 12-02-2012, 15:42
byteit101's Avatar
Not yet, I'll try that on Monday. The really funny thing is I got it working last tuesday, and did not touch it after that, but on wednesday at the school open house, it started this issue
Watchdog.Kill();
