Go to Post I am specifically looking for Rhode Island, Hawaii, New Hampshire, Nevada, California, Florida, ... oh heck, all of the rest. - Rosiebotboss [more]
Unread 04-01-2003, 17:14
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Spectacular kit of parts
I would agree with FIRST that this is probably the best kit of parts ever. The motors were greatly improved this year.
1. The Van Door motor is back! Anyone who participated before last year will recognize them.
2. The drill motor is larger and more robust. This will hopefully mean fewer blown drill transmissions .
3. Some of you might have overlooked this, but the Atwood motors finally have a real output shaft! No longer do we have to work with that impossible to match set of tapered gears.
The change I was most relieved to see was a different circuit breaker. This one seems more like a switch rated breaker and seems less likely to trip in a hard collision.
Unread 04-01-2003, 17:55
Generator of Entropy
FRC #2973 (The Mad Rockers)
No doubt. I'm sure our gearbox designer is drooling - He's in CT and we're in FL.
Unread 04-01-2003, 18:10
Matt Reiland's Avatar
'The' drive behind the drive
The manual says that the main breaker is rated at 120A and you have 4 available 40A circuit breakers for the bigger motors!!!
Unread 04-01-2003, 18:33
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Aw... doesn't it take all the fun out of fabricating your own parts!?!
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 04-01-2003, 19:17
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
Score!! Those 40A breakers will be a help but of course we will find a way to blow the breakers!
Those Van door motors will be a big help this year and the new parts for the atwoods will help. Of course our tranny did not need them, we won the Brunswick Eruption speed contest thanks to our tranny!
Fear our Tranny!
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Unread 04-01-2003, 20:09
jmo8605's Avatar
jmo8605 jmo8605 is offline
jmo8605 is an unknown quantity at this point
Send a message via AIM to jmo8605
My team isnt opening the kits till tomorrow b/c we didnt have time, so i was wondering if anyone got a chance to take the new drill motors apart? easier, hard, same?
Jon
Unread 04-01-2003, 21:38
Hi All,
There are big changes in the kit this year and I will reserve judgement for a few more weeks. However, things look very nice on what I have seen so far. The new drill motors look more robust, have larger brush assemblies that can be soldered directly to, but are more open to the elements (i.e. shavings and dropped hardware.) The 120 amp circuit breaker has actual mounting holes, large attachment bolts and at least appear to be less sensitive to shock. Don't let the 120 amp rating fool you, though. I predict if you had problems with high currents that tripped last year's breaker, you will still have problems this year. 40 amp circuit breakers for only four of the motors through the use of a larger, prewired, circuit breaker block. Again, don't expect this to fix high drive current problems. Finally, there is a smaller light assembly, but do not have specs on this part yet. Lot's of other improvements as well as an interesting game.
Unread 04-01-2003, 21:44
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
The light's a lot more quiet and it has that European Emergency vehicle look.
Unread 04-01-2003, 21:49
Elgin Clock's Avatar
FRC #0237 (Black Magic)
You mean like the custom motor mounts for the drill motors, and our awesome custom planetary gear box for the globe???
Yeah, those custom motor mounts for the drill motors look really heavy. Professionally done, yes, But heavy!
Unread 04-01-2003, 21:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The old bosch trannies had 3 planetary gears in each set. These new ones have 5! The shifter is way better too.
Does anyone know if the ring gears are plastic still or metal for the new ones?
Unread 04-01-2003, 21:57
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
I noticed the 5 gears too. If the ring is still plastic it has to be tougher because of the demands of a drill like that. Although metal would still be preferable.
Unread 05-01-2003, 00:55
DLyons DLyons is offline
#0910 (Ventures)
DLyons is an unknown quantity at this point
if they are plastic I know we will be making soe gears out of some sort of metal
team 910
I love FIRST
2003-Seed 8 @ West-Mich Regional
Sad to see I am done on the student side, now I will have to mentor
Unread 05-01-2003, 11:51
Rick Gibbs Rick Gibbs is offline
#0145 (T-Rx)
Rick Gibbs is an unknown quantity at this point
The shifting ring gear is still plastic.
Unread 05-01-2003, 12:12
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
You've obviously taken them apart. Do they look any stronger than the old ones?
Unread 05-01-2003, 13:29
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
the problem this year is to make a new lock out for the clutch.
and if someone could show me how to get the shaft out of the drill.
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Size of the kit of parts jrgrim12 Kit & Additional Hardware 5 24-12-2002 14:53
My Digital 'Kit of Parts' For My Friends archiver 2000 7 23-06-2002 22:33
Inventor drawings of parts from kit patrickrd Inventor 1 11-01-2002 14:16
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
