Go to Post rookie teams are like kids - making them is easy but raising them to maturity can kill you - Wayne C. [more]
Unread 07-02-2012, 21:26
CHRobotics CHRobotics is offline
FRC #0580
CHRobotics is an unknown quantity at this point
Digital #1 outputs not displayed in dashboard
The outputs from digitial #1 sidecar are not displaying on the dashboard. We are particularly interested in the pwm cable outputs to the speed controllers and the dashboard is not displaying the signal strength. Relay states and GPIO states are not also displayed.
Unread 07-02-2012, 22:23
Re: Digital #1 outputs not displayed in dashboard
See http://firstforge.wpi.edu/sf/go/artf1439 for a description of the bug and the solution.
Unread 12-02-2012, 04:57
Clifcecile's Avatar
Clifcecile Clifcecile is offline
Project liaison
FRC #4060 (Team SWAG)
Clifcecile is on a distinguished road
How do we fix this problem if we are using Wind River? Warning we are rank rookies here. We have things running but nothing displays on dashboard .
Unread 12-02-2012, 10:15
You can use LabVIEW to make the code change and rebuild the dashboard. Or you can ask that someone send you a corrected Dashboard.EXE that you simply place in the Program Files/FRC Dashboard folder.
Greg McKaskle
Unread 12-02-2012, 10:26
At least in previous years (I haven't checked this year), the default c++ project did not send dashboard data. There was an example project which shows how to send dashboard data.
The LabVIEW problem is on the robot side and only affects teams using LabVIEW on their robot.
Unread 12-02-2012, 20:19
Joe is right. The bug is in the Build Dashboard. It shouldn't even be necessary to rebuild the dashboard. My mistake. Instead look at whether your code is sending values back and if the dashboard is displaying is correctly.
Greg McKaskle
Unread 13-02-2012, 15:47
austin1743 austin1743 is offline
Head Programmer - Java
FRC #1743
austin1743 is an unknown quantity at this point
after reading this, i have found that our team is having the same issue. Did you guys come up with a fix for this?
my team uses java and we are having the same issue.
Team 1743
Head Programmer
Unread 13-02-2012, 16:06
The java default projects do not update the dashboard. Look at the DashboardExample.
Unread 13-02-2012, 16:19
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
A picture is worth a 1000 words.
Name:	Remove Increment.JPG
Unread 13-02-2012, 16:21
FRC #1743
oh, thanks i thought the java defaults update the dashboard but now that i see that it doesn't i will change it, thanks.
Team 1743
Head Programmer
