Go to Post A stack is a stack is a stack. (How Profound!) - Paul Copioli [more]
Unread 04-02-2012, 17:30
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Restricting Window Motors Number of Turn
Hi everybody,
We wonder if we can restrict our window motors number of turn in our code. Regardless how long we push the button we want the window motor to stop at some point.
Is it possible to do it in our code?
Thanks in advance...
Unread 04-02-2012, 18:04
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Restricting Window Motors Number of Turn
You'll need some form of sensor for feedback to the controller. Options include: digital encoder, potentiometer, limit switch, magnetic sensor...
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 04-02-2012, 18:17
DonRotolo's Avatar
Back to humble
FRC #0832
That sensor David mentioned will tell your code exactly where the motor shaft is, and thus how many times the motor has turned. It is not terribly difficult. Your choice of sensor depends on how many turns you need to count and what your budget is.
Note that trying to do it by "dead reckoning" - that is, by guessing the motor's position according to time that it has been supplied power - will be disappointing.
Unread 04-02-2012, 18:36
Originally Posted by cilginbilgin View Post
Hi everybody,
If you could provide a bit more detail about your design and what you are trying to achieve, it might be possible to give you a more targeted answer concerning what type of sensor to use.
Unread 05-02-2012, 05:02
FRC #2905
Red face Re: Restricting Window Motors Number of Turn
Here we have a drawing of the mechanism. Window motor will control the damper. We want damper to go down and up.
http://imageshack.us/photo/my-images...allholder.png/
Unread 05-02-2012, 07:59
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I changed the quote from a URL to an embedded image.
Limit switches are your best bet. There are some Honeywell ones in the kit to use. One that triggers when the damper touches the holder and one that triggers when the damper is fully open.
Unread 05-02-2012, 14:00
FRC #2905
Question Re: Restricting Window Motors Number of Turn
Is that for sure? Because mechanics in our team refuses to use limit switch.
Unread 05-02-2012, 14:17
Since you're using a window motor, and it looks like you've got hard stops at each extreme, you may be able to get by without a sensor if the load on the damper is known and sufficiently consistent so you can time it properly.
Unread 05-02-2012, 14:58
FRC #2905
Thank you David, Max, Don and Ether. We will try to do it without sensors because mechanics in our team are lazy.
Unread 05-02-2012, 16:49
cgmv123's Avatar
AKA: Max Vrany
Keeping track in code would be harder in my mind. And electrical has control over sensors on our team.
Unread 12-02-2012, 10:29
FRC #2905
We tried to figure out how to restrict window motors and we created a while loop in the timed.vi because using while loop in the teleop.vi is not recommended. Are we supposed to put the while loop in the timed vi or in which vi should we use the while loop??? Thanks in advance!!!
Unread 12-02-2012, 15:02
I'm not a LabVIEW guru and I don't have LabVIEW installed here so I'm not equipped to give you LabVIEW-specific examples, but I think you want to put the equivalent of this into the periodic tasks vi:
while (1) {
if (!run_me) {sleep(20ms); continue;}
run_me= false;
doSomething;
sleep(3000ms);
doSomethingElse;
"run_me" is a boolean global variable. Whenever your TeleOp code sets it to "true", the code in red runs once.
The "doSomething" would be to turn your motor on. The "sleep(3000ms)" would be how long you want to leave the motor running. The "doSomethingElse" would be to turn the motor off.
The "sleep(20ms)" is there to limit how fast the code polls "run_me" while waiting for it to become true. Without the sleep, this loop would always want a slice of CPU time. That would waste resources. Make the 20ms as long as tolerable and only as short as necessary.
Perhaps a knowledgeable LabVIEW person could post a code snippet.
