Re: Running PD Board from an outlet
I doubt that would get you enough current do run anything. You might be able to run the cRio and digital sidecar, but certainly not any motors. The CIMS (on the robot) are wired to 40 amp breakers, I doubt that even puts out 1 or 2 amps.
We have no motors or Jaguars hooked up. Only the cRIO and a digital sidecar. Everything else is either not connected or already powered via a power strip on the board.
Some of the switching supplies in the PDB are not very friendly to this approach. I strongly recommend staying away from it unless you really know what you're doing.
By "not friendly" you mean they are only going to work for a specific setup? If so, what is it looking for? I've moved on to the idea of using a laptop 12 volt power supply instead as it would probably be closer to the correct voltage and provide enough current. If I knew what they are looking for I can try a different power supply that is more appropriate easily.
Where did your 135A stat come from?
#7
12V@135A is listed on the spec page on newegg for the linked power supply.
#8
A pc power supply like the one from newegg could run the robot.
to power it on, connect the thin green wire to ground on the motherboard connector. |
#9
If you just want to program things and not make anything move, any clean 12V >30W power supply will do. The original part linked is likely to put out incredibly dirty power, I would not try it. The power supply module linked will likely work nicely.
Be sure not to use the battery charger as a make shift power adapter - they can interact poorly. |
#10
If you're making and buying things, why not just get an extra charger, it will likely have more uses to you and your team.
#11
Eric,
What power supply wattage would be needed to run motors off of? |
#12
Decide how much power the motor takes. Worst case for a CIM on a 40A fuse is going to be 12V*40A = 480W coming from the power supply. Add up all the motors you want to use to get a worst-case idea.
with a 500W power supply, you can test 1-2 motors at a time under full load. If your wheels are not on the ground, they are not at full load, so maybe you can run 4 motors or so. |
