Go to Post Does this need a "Do not try this at home" stamp? - sanddrag [more]
Unread 12-02-2012, 15:05
Re: 2 issues in one possibly related (cRIO/ Camera)
You won't see the camera view on the default Dashboard unless you set the camera's IP address to 10.te.am.11 and connect it to the D-Link. You also have to give it 5 volt power; there's a dedicated output for that on the Power Distribution Board.
Does the light around the camera lens turn green when you try it?
