Go to Post FIRSTers in particular want very strictly delineated guidelines so that they know exactly what parameters under which they're working, except when they don't. - pfreivald [more]
Unread 12-02-2012, 15:21
aire aire is offline
aire is an unknown quantity at this point
Re: Running PD Board from an outlet
12V@135A is listed on the spec page on newegg for the linked power supply.
Unread 12-02-2012, 15:30
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
A pc power supply like the one from newegg could run the robot.
to power it on, connect the thin green wire to ground on the motherboard connector.
Unread 12-02-2012, 16:31
If you just want to program things and not make anything move, any clean 12V >30W power supply will do. The original part linked is likely to put out incredibly dirty power, I would not try it. The power supply module linked will likely work nicely.
Be sure not to use the battery charger as a make shift power adapter - they can interact poorly.
Unread 12-02-2012, 16:57
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
If you're making and buying things, why not just get an extra charger, it will likely have more uses to you and your team.
KK4KQO
http://voltair.us
Unread 12-02-2012, 18:16
Eric,
What power supply wattage would be needed to run motors off of?
Unread 12-02-2012, 18:26
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Decide how much power the motor takes. Worst case for a CIM on a 40A fuse is going to be 12V*40A = 480W coming from the power supply. Add up all the motors you want to use to get a worst-case idea.
with a 500W power supply, you can test 1-2 motors at a time under full load. If your wheels are not on the ground, they are not at full load, so maybe you can run 4 motors or so.
Unread 12-02-2012, 19:04
Originally Posted by aire View Post
Eric,
For a full robot on the ground? Somewhere in the range of 2-6kW.
For testing subsystems while up on blocks? 1kW might do it.
Actually, a CIM can easily draw 100-130 Amps at stall depending on wiring. When a breaker has a 40 Amp rating, it means that it can sustain 40 Amps indefinitely.
EDIT to add:
Regenerative breaking can play havoc with some power supplies. Where a battery would simply accept the regenerated charge, some power supplies will go high-impedence to protect themself. The voltage can spike and destroy the supply or the robot electronics.
Unread 12-02-2012, 20:34
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
For just powering the electronics, a small 12 volt power supply will work. I imagine you could dig one out of an old computer.
To survive a regional you are going to need lots of batteries and an extra charger. So buying that now would be a good idea. If you are not running motors or running them lightly loaded, the robot battery lasts a long time.
Unread 12-02-2012, 21:22
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
MAldridge will become famous soon enoughMAldridge will become famous soon enough
I second the computer power supply. Ask your school's tech department if you can get a power supply out of a dead computer. Those can easily put out a huge amount of clean current (I currently use one to drive the stereo in my school's NOC).
A word of warning though, those can put out dangerous amounts of current, make sure you know what you're doing when working with it.
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
Unread 12-02-2012, 23:21
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
They can also retain lethal voltages, with all their capacitors and what not, even when unplugged. Don't ever open a computer power supply!!
Unread 12-02-2012, 23:32
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
You do know the battery will put out a lot more current than your typical power supply? Even with big capacitors? But you point is well taken.
If you use a car charger, keep the battery connected as well. It will clean up the charger's dirty power. Just do not use a charger that has a start the car mode.
Unread 13-02-2012, 09:45
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I recently measured our control board at .9A drawn during motor idle period. Aboard are the usual suspects and 6 jaguars. To this you would have to add the motor currents as noted above. Connecting some other source of 12vDC could be done, but as you can tell from the comments, this designation covers a lot of supply waveforms and reactions by the supply.
The other thing you should consider is getting some additional energy supply gear for your team. Perhaps you already have it, and were only talking about powering the board during a home-based session. We've done this too. You have to be very careful not to discharge the legal batteries too deeply. They can be damaged by it. Be sure to search CD for more discussion of battery and electrical practices.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 12-02-2012, 23:19
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
I've used a car battery charger to power a minimal control system (digital sidecar, cRIO, camera, single motor) through a power distribution board. I'm guessing this power isn't much cleaner than that from the car adapter. Does the dirty power permanently damage parts or is it simply unreliable?
I have also used a PC power supply to power the newer cRIO directly (accepts as few as 9 volts) but have not attempted to power anything through the PDB.
