Go to Post Result: 44 volts through the DAP-1522. NOT FUN. - DtD [more]
Unread 12-02-2012, 16:06
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
nydnh01 is an unknown quantity at this point
Kinect in Dashboard
I was wondering how is it possible to have the x and z coordinates move with the y axis on the skeletal image for the Kinect?
Unread 12-02-2012, 16:16
Re: Kinect in Dashboard
Yes, it's possible.
You are allowed to write changes into the Kinect Server.
If you've installed the FRC Kinect Server, then the source and documents arte located on your Local Disk at: C:\\Program Files\FRC Kinect Server
I'd start by looking at the document (under docs):
Getting Started with Microsoft Kinect for FRC.pdf
Unread 28-02-2012, 07:29
JChavis's Avatar
JChavis JChavis is offline
Team 3490's "Pro./Electrician"
FRC #3490 (Vyper Drive)
JChavis is an unknown quantity at this point
Originally Posted by Mark McLeod View Post
Yes, it's possible.
Just Make sure that you have also installed Microsoft Visual C# Express 2010 so that you can follow along the Kinect Code Walkthrough pdf....(Below)
The Images I have attached are of course not from Visual C#, but from Notepad (which I would not recommend using), since I don't have Visual C# on the computer I am Posting to You Now!
Note: I have only started using Visual C#, so my changes may not be the complete way to change the code to include the "Z" Axis.... . I have only followed the Walkthrough in the FIRSTGestureProcessing Section...
Name:	Kinect Change 1.PNG
ID:	12145  Click image for larger version
Name:	Kinect Change 2.PNG
ID:	12146  Click image for larger version
Name:	Kinect Change 3.PNG
Hmmm....I wonder if I can create a robot lawnmower with the knowledge I have gained from FRC.....
