Go to Post The sign of a mature community is not that everyone is nice and happy but that differring opinions can be expressed. -Joe Johnson - archiver [more]
Unread 11-02-2012, 13:52
matthewjardell matthewjardell is offline
FRC #4283
matthewjardell is an unknown quantity at this point
RSL Issues
We cannot get our RSL to turn on when it is connected to the DSC. It worked fine when we had it connected to the PD. Any suggestions?
Unread 11-02-2012, 13:56
EricH EricH is online now
Re: RSL Issues
Have you done the DB-37 cable check and rework as described in http://www.usfirst.org/sites/default...tructions.pdf?
Is the DSC powered?
What is the RSL light on the DSC (a green LED next to the letters "RSL") doing?
These questions are meant to help guide you in troubleshooting, and allow us to give better advice as to the cause of the problem.
Unread 11-02-2012, 14:47
Derek012's Avatar
Derek012 Derek012 is offline
I miss my frisbees
FRC #4564 (Orange Chaos)
Derek012 is on a distinguished road
Re: RSL Issues
Ive ran into a similar issue while I was setting up the electronics this year, Its turns out I just had a bad connection to the terminal in the PDB.
Unread 12-02-2012, 19:19
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Cool Re: RSL Issues
I have similar issues. Look at my thread recently posted. There is a lot of insight.
http://www.chiefdelphi.com/forums/sh...d.php?t=102559
I hope this helps and Happy Competition!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 17-02-2012, 11:29
FRC #4283
Re: RSL Issues
Yes we have done the DB-37 rework and the DSC is working fine. The RSL light on the DSC is not working.
Unread 17-02-2012, 11:35
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: RSL Issues
If the green light on the DSC is not working, then your problem isn't your RSL. double check the cable with a multimeter, and make sure all pins transfer through correctly. When we fixed ours the first time, it turned out that only about half the pins got through correctly (the half in the middle were the problem...), so some things worked fine, but the RSL did not.
Unread 17-02-2012, 11:42
FRC #4283
Re: RSL Issues
Yepp that helped. Pins 5-13 were'nt working, but we've fixed it. Thanks!
