Go to Post STEM blushes, and asks if Art would like to go out for a date. - Cothron Theiss [more]
Unread 09-02-2012, 19:47
Sinani201 Sinani201 is offline
AKA: Daniel
FRC #1836 (Milken Knights)
Sinani201 is an unknown quantity at this point
Same cRIO's respond differently
We have two cRIOs with the exact same hardware/software, but the imaging tool doesn't see the 9403 module for one of them, and the driver station reports no communication. Pinging the robot does work. When we swap one for the other, everything works fine. (We have tried both CRIOs with exactly the same modules and wiring. One works, one doesn't.)
Any help would be greatly appreciated.
Unread 09-02-2012, 22:07
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Same cRIO's respond differently
Your best bet would be to contact NI to see if it can be replaced.
Are these 8-slots or 4-slots?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 09-02-2012, 22:40
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Consider opening the non-working cRIO and blowing out any accumulated foreign debris with compressed air.
This is especially applicable if this is an older cRIO without the gaskets installed. Dirt can get in the port openings, and cause strange things to happen.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 10-02-2012, 19:03
AKA: Daniel
Here are errors from the NetConsole, if it helps.
>>>>ERROR: status = -63194 (0xFFFF0926)  ...in GetDIO() in C:/WindRiver/workspace/WPILib/DigitalModule.cpp at line 325
Too much error data!
>>>>ERROR: status = -63194 (0xFFFF0926)  ...in SetRelayForward() in C:/WindRiver/workspace/WPILib/DigitalModule.cpp at line 168
Unread 12-02-2012, 21:00
slijin's Avatar
Pockets
AKA: Samuel Lijin
You may want to repost this in the Programming forum, or PM one of the NI guys (like Greg).
Unread 12-02-2012, 23:25
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Are the cRIO image and WPILib up to date? That error code (−63194) corresponds to "NiFpga_Status_VersionMismatch" on the following page:
http://zone.ni.com/reference/en-XX/h...1/capi/errors/
Unread 13-02-2012, 19:15
AKA: Daniel
Hi everyone, sorry for the late response.
This is a new cRIO and it hasn't been used until now. It's 4 slots and has the latest image.
We're going to try to contact NI to see if it can be replaced. Until then, does anyone else have other ideas?
Unread 13-02-2012, 23:58
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
It may be possible you have a bent pin. Do other modules show up?
Unread 15-02-2012, 19:55
AKA: Daniel
Yes, all the modules show up as green in the imaging tool.
Unread 16-02-2012, 08:21
We found recently that there are "soft" switches in the imaging tools. I don't know what that means but it was reported from one of our software guys after one of our Crios was taking a very long time to run a loop.
