Go to Post When you're in a field as deep as the Championship go offensive or go home. It's that simple. - thefro526 [more]
Unread 13-02-2012, 00:16
Re: View Sensor data on Dashboard..
You have a couple of options. You can "print" the data to the User Messages window on the Driver Station. Or you can flatten the data into a string and pass it to the Set User Data Hi vi (found in the Driver Station palette), then modify the Dashboard to take the "high priority user data" string and unflatten it to match. The result can be fed to whatever indicator you want to place on the Dashboard's front panel.
Unread 13-02-2012, 01:13
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Well I'm a pretty rookie programmer so I really don't understand how to do this. Can you give me an example.
Unread 13-02-2012, 11:38
Tutorial 7 on the LabVIEW getting started window shows how to send data to the dashboard.
Unread 13-02-2012, 23:15
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
The way we are doing this is:
1. Storing data we want on the dashboard to global variables (define the variables in Robot Global Data VI, then write to the data to these variables.
2. Update the Dashboard Data Typedef with the variables we want to pass to the Dashboard.
3. Read data from global variables and store into the Dashboard Data Typedef in Build Dashboard Data VI.
4. In the Dashboard Project, read the data and pass to Indicators
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
