Go to Post The real world doesn't snap together easily. - Joe G. [more]
Unread 07-02-2012, 00:45
wireties's Avatar
wireties wireties is online now
Principal Engineer
AKA: Keith Buchanan
modifying banebots transmissions
Anyone in CD land ever successfully modified a banebots transmission to remove a layer or two?
TIA
Unread 07-02-2012, 01:00
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: modifying banebots transmissions
Yes, many times. It's a piece of cake- you just need to know what you are doing with a lathe. Also check this out for how to keep them from grenading on you: http://www.chiefdelphi.com/forums/sh...our+ banebots
Be warned- they are very fragile!
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 07-02-2012, 01:03
fox46's Avatar
And just so you don't have to read through the posts by the skeptics - the output shaft mod as described worked flawlessly through our whole competition with no failures.
Unread 13-02-2012, 01:05
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
I got a reply from banebots - they said to buy a shorter ring gear and shorter screws and simply remove a stage!
Thanks for the help CDers!
Unread 13-02-2012, 08:54
fox46's Avatar
You don't need to buy anything- just turn the ring gear down on a lathe to shorten it and cut the screws down... No need wasting $$ and waiting a week for a new ring gear.
Unread 13-02-2012, 09:02
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
I second the DIY approach. In fact we took a stage out of 4 P80's last gear for our drive train with an end mill (our lathe didn't have the proper tools). They held up perfectly through two regionals.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 13-02-2012, 10:26
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Thanks guys!
