Go to Post Robotics is fun, but it isn't the most important thing in life. - Wayne TenBrink [more]
Unread 04-01-2003, 19:56
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
What about the DQ multiplier?
Many people are miscounting containers. There are 8 containers per alliance, and 29 in the middle. That is 45 containers.
23 containers * 22 containers = 506 pts
2 robots * 25 pts/each = 50 pts
556pts * 2 DQ multiplier = 1112 pts
1112 points is the maximum a team can achieve.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 04-01-2003, 19:57
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Originally posted by IsabelRinging
Oooh, but don't forget the situation where the height of the stack is higher than the actual number of boxes in the stack.
So...
24 stack height x 22 boxes + 50 = 578 points
0 stack x 0 boxes + 50 = 50 points
578 + 50(2) = 678 QPs/EPs
One problem... There aren't 46 tubs.
The HIGHEST score is actually:
2(23 Stack Hieght x 22 boxes + 100)= 1212 points
Where does the first 2 come from? If an opponent is disqualified you get twice your own score. It isn't likely, but I believe last years high score was set by a team that profited from a rule similar to this.
I'm editing this because while I type this 3 other people posted as well (Only on CD) .
Anyway Someone else said that you couldd stack them on their side to get 942 (946?? I don't remember). Just double it and that's the highest.
1884 Points (Good Luck)
Unread 04-01-2003, 19:59
Joel J's Avatar
Joel J Joel J is offline
do you..
hrm.. seems to me.. that:
Red
Stacked: 23
On Ground: 23
On Ramp: 2
23 x 23 + 50 = 579
Blue
Stacked: 0
On Ground: 0
On Ramp: 2
0 x 0 + 50 = 50
The kicker? Blue gets disqualified, thus making the final score of the red alliance: 2*579, or 1158.
This is impossible.. if anyone were to do this, I would shake their hand.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 04-01-2003, 20:01
Joel J's Avatar
do you..
hrm.. May I ask where you got that 100 from?
Joel Johnson
IsabelRinging's Avatar
IsabelRinging IsabelRinging is offline
Yay! Custom title!
None #0180 (SPAM)
IsabelRinging is on a distinguished road
The stack of 24 box height actually consists of 23 boxes. One of them is stacked on its side or upside down, making the height of the stack exceed 23 boxes. They demonstrated how this can happen during kickoff.
SPAMinating the countryside.
  • 2004 UCF Semifinalists (Thanks to 179 and 1083)
  • 2004 Palmetto Quarterfinalists (Thanks to 34 and 435)
  • 2003 Robot Rodeo champions (Thanks to 108 and 186)
"In addition to the cut of your gib, I likes the sound of your town."
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
So then:
2(36 Stacked the long way x 22 boxes + 50) = 1684 ??
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 04-01-2003, 20:05
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Sure. From What I gathered from the kickoff, if a robot is on top of another, the bottom robot gets an extra 25 points for having them on the ramp. If both of your robots cariied two others you could get 100. However, this should be cleared up by first.
Unread 04-01-2003, 20:06
Noelle Noelle is offline
#0180 (S.P.A.M.)
Noelle is on a distinguished road
Send a message via AIM to Noelle
Points
Hey, the highest possible score will always come from having an equal pile of boxs in the stack and on the ground. That's where the whole quadatic equation comes into place. (parabola would have the highest point where ax squared= bx)
SPAM rules!
Unread 04-01-2003, 20:09
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Yeah I forgot that, and actually you could go much higher than 24.
#0180 (S.P.A.M.)
No, the top robot just gets the scoring points of the bottom robot, 25 if the bottom gets them, 0 if the bottom robot doesnt. But what if the top robot isn't totally in the scoring area?
SPAM rules!
Unread 04-01-2003, 20:12
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Re: Points
Good call. That's where the 942 in an earlier post comes from. That would make 1884 the higest score.
Unread 04-01-2003, 20:20
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Anyone take into account yet, that the top bin of a stack can be turned on it's side to give you the height or one more bin? Remember: It's not how many bins you have, it's the height that counts!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 04-01-2003, 20:25
#0180 (S.P.A.M.)
how?
Originally posted by AJ Quick
So then:
36 stacked the long way? how is that?
SPAM rules!
Unread 04-01-2003, 20:32
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Re: how?
even though its probably impossible, use your imagination- stack the boxes so that their longer side faces up in the air-
Unread 04-01-2003, 20:36
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
- Katie
This was already mentioned.
Fantasy Football! EddieMcD Chit-Chat 176 30-12-2003 18:30
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Chamionship Qualification - feedback needed ASAP! dlavery General Forum 97 11-10-2003 07:17
Seeding Calculations archiver 2000 50 23-06-2002 21:57
