Go to Post I tried to write a scouting app and wanted to throw my desk out a window... - tjf [more]
Unread 11-02-2012, 16:45
blackwood blackwood is offline
FRC #2359 (RoboLobos)
blackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to beholdblackwood is a splendid one to behold
Using 2 digital side cars
Our team is having problems trying to use two digital sidecars.
We are using JAVA, and the code compiles but says there is no second digital module,(and we have two attached) and that the channels we are trying to use are already allocated.
Any suggestions?
Thanks.
Unread 11-02-2012, 16:48
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Using 2 digital side cars
are your modules in the proper slots on the crio? When you image the rio does the imaging tool recognize all of the slots being used properly?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 11-02-2012, 17:09
Yes they are in the proper slots, and yes the imaging to for the c-rio recognizes all slots as being used properly.
Unread 11-02-2012, 17:12
on the bright side that all but eliminates a mechanical connection issue, so that leaves it to the way you call the devices in your code. Unfortunately not being a java guy this is where I have to say good luck and hopefully someone with experience in the programming area can chime in... When I see these threads I know the first thing people want is to see the code where you activate and assign channels.
Andrew Basse
Unread 11-02-2012, 17:16
Thanks for trying. Hopefully someone will have more advice soon!
Unread 11-02-2012, 19:11
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
I know that this is going to sound odd, but have you checked the modules themselves? At the beginning of our season, we hit a snag and our programmers tore hairs out trying to fix code until it turned out to be a bad module.
Academic Student (Forever)
Unread 11-02-2012, 19:14
JByrd's Avatar
JByrd JByrd is offline
AKA: "The Word"
FRC #0829 (Digital Goats)
JByrd is an unknown quantity at this point
when you construct your inputs and outputs do you have the code written with the module number like this:
DigitalInput input = new DigitalInput(2,1)
(for a digital input in port 1 on the module on slot 2 of the cRIO)
or
DigitalInput input = new DigitalInput(4,1)
(for a digital input in port 1 on the module on slot 4 of the cRIO)
I'll tell you anything random that you don't want to hear
Unread 11-02-2012, 19:20
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
I have to second this.
Try reversing your modules (move the one from slot 2 to 4 and viceversa) and see which ones work.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-02-2012, 11:26
or
If you do have the program written like this, fix it. You shouldn't be referencing slot numbers in the code. The first digital module (in slot 2) is module 1. The second digital module (in slot 4 of a 4-slot cRIO or slot 6 of an 8-slot cRIO) is module 2.
Unread 13-02-2012, 12:38
Thanks. I will pass this on to our programmers. Just curious, where did you find this information? If there is some documentation that has this info, I would appreciate it.
Unread 13-02-2012, 12:50
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
The WPI Getting Started with Java Guide:
http://firstforge.wpi.edu/sf/docman/..._documentation
Page 15: Constructors with Slots and Channels
Unread 13-02-2012, 19:49
Thank you everyone. We got it to work!
