Go to Post PS: Sorry for derailing this thread even further. - Molten [more]
Unread 11-02-2012, 17:22
pigpenguin's Avatar
pigpenguin pigpenguin is offline
Registered insane
AKA: Ethan Rooke
FRC #1160 (Titanium Robotics)
pigpenguin is an unknown quantity at this point
Lexan heating strip / tape
Hello Chief Delphi,
Our team is looking for a lexan bending strip. Can anyone recommend somewhere in which we could find one in Southern California?
Thanks in advance
1160
"Insanity isn't a plea its a way of life and here we are all one card short"
Unread 11-02-2012, 19:07
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Lexan heating strip / tape
If you need a quick fix, you could use a heat gun on high to do the bending. It's not as pretty as a strip heater, but it would get the job done.
Academic Student (Forever)
Unread 11-02-2012, 19:12
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
You can also bend lexan in a sheet metal break as long as you don't need more than a 90 degree bend. We did that for all of our shielding last year and it is still doing its job just fine as it sits in the corner of the shop. Everything we used was 1/8 inch material, thicker might be tougher but could still work...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 11-02-2012, 22:29
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Check for a Tapplastics.com store in your area they sell a heater strip for a DIY kit or a ready to go line bender.
Unread 12-02-2012, 02:05
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
How well did this work? Did you have to heat the material at all or do anything special before hand?
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 12-02-2012, 03:58
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
No, lexan is quite flexible; you just have to bend it past the angle you want because of its rigidity. Angles are also hard to get right; I find that the effective bend radius is ~2x the thickness of the lexan when done in a break. It works quite well when done right though.
Heating is only necessary for custom molding (e.g. cylindrical shapes), although it's very difficult to do (a clean job) without experience.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-02-2012, 04:04
Best Available Data
FRC #1778 (Chill Out!)
All of the bends on this robot were done in run of the mill sheet metal break without any prior preparation. I would agree you have to go farther than you want as it flexes back slightly but it is pretty straightforward. As you get closer to 90 degrees you might start to see microcracks appear, but we never had any panels fail (although we never really used them in load bearing situations).
Unread 12-02-2012, 16:06
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
We also bend all of our Lexan on a cheap sheet metal break from Harbor Freight. They are on sale right now for $224. Maybe you can even use a cupon get another 20% off.
Unread 13-02-2012, 13:23
Garret's Avatar
AKA: Garret Smalley
That's good to know, I am rather new to bending material so I really didn't know what would work (well at least bending precisely/intentionally ).
7 Years of FRC
Unread 13-02-2012, 15:40
Elgin Clock's Avatar
FRC #0237 (Black Magic)
One year we used a sheet of lexan & a heat gun & just heated it up as we were wrapping it around a 55 gallon drum.
We then used tie-downs to hold the bent piece in place while we went to dinner & when we came back it stayed in the arc shape of the barrel upon releasing the tie-downs.
