Go to Post A career is never static. - Bill Moore [more]
Unread 02-02-2012, 16:06
techno4229 techno4229 is offline
AKA: marcus
FRC #4170
techno4229 is an unknown quantity at this point
Question Flashing Yellow Jaguar
ok we are rookie team and im having problems with the motor controls im using labview but when i leave everything on defualt when i followed tutorial i ran the file and it said everything was working but i get a yellow flashing light in the black jaguar and when i use the joysticks nothing happens to the motors any help vets or anyone who knows what to do???
Unread 02-02-2012, 16:30
Re: Flashing Yellow Jaguar
Check your connections. The yellow flashing light on the Jaguar means no signal.
Some other things to check:
--DB37 cable from the second module to the Digital Sidecar
--PWM orientation from Sidecar to Jaguar (had that with a team last week)
--Robot code loaded
--Robot enabled in teleoperated
What is the RSL LED on the Sidecar doing?
Unread 02-02-2012, 18:15
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Some of the ribbon cables in the kit were not assembled correctly:
Originally Posted by dyanoshak View Post
Also, check to make sure that your ribbon cable was assembled correctly. See this document from the FIRST website: DB37 Ribbon Cable Assembly Rework Instructions
This was posted in the team updates, be sure to follow them!
Unread 02-02-2012, 20:30
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
Learn to speak English Then you may want to check your ribbons, as there were some defective ones sent out.
No leaks. Ever.
Unread 13-02-2012, 13:28
AKA: marcus
FRC #4170
--Robot code loaded
um...
--Robot code loaded
i need help loading the robot code i enable in teleoperated and it for the main drive any clue what to do?
