Re: Victor reversed wiring...
I don't want to sound alarmist, but you have to accept that you have caused some amount of damage to these parts. Have spares ready. |
In 2000 when I was in grade 10, our school used to participate in the now defunct "Canada First" robotics competition- brainchild of the late Bruce MacMillan, a spinoff of FIRST before the GTR regional came into existence. That particular year the competition organizers had designed a custom control board that when interfaced with an RC aircraft system provided control to the robots. Unfortunately the system was plagued with problems in the form of exploding MOSFETs/Transistors and the on-board microprocessor. The cause was a poor design where the designer had overlooked this kind of protection. Voltages which backfed to the controller when the power was turned off (so we were told) was causing the processor to cook itself- just like you describe. The motors we were supplied with were windshield wiper motors with very little "spindown" and were virtually impossible to backdrive which meant only a very small amount of power was needed to cause this condition. This is why I am convinced the Victors and Jags have at least some tolerance to reverse voltages otherwise I am confident they too would cook. The solution to these issues that was implemented AT the competition was replacing all the power switching hardware on the boards with relays resulting in only "ON/OFF/ON" control. |
Hooking a battery up would be far worse then extensive "pushing around".
Well if you're hooking up the battery where the motor goes then the current will flow through the motor (and possible backwards to the controllers) if one of the mosfets from the top and the opposite from the bottom is on. If both bottom or both top mosfets are on, such as in brake mode, then you'd be shorting out the battery.
Fox,
Unfortunately the answer is NO, there is nothing in the way of backward protection. The FETs have a diode that is across the terminals that results from the manufacturing process. If you look at the spec sheet you can see the diode and the direction in which it conducts. The four legs of the "H" bridge do conduct as a full wave bridge and provide power of the correct polarity at a reduced voltage backwards to the power rails of the controller. These diodes do have a forward voltage drop though, so the conducted voltage isn't quite what you would think. Remember that when the controllers are powered correctly, and a 'coast' condition is commanded, all of the FETs are off and current only flows through the diodes (the same is true for pushing with power off). When a 'brake' is commanded both low side legs of the controller are turned 'on' resulting in a short across the motor but no power being delivered to the controller internals and no current flowing through the diodes. In the case of the power leads being attached to the output terminals, we don't know if they were wired in a normal polarity. In any case, considerable current may flow through the controller restricted only by the breaker feeding the device. Depending on the duration (or repeated attempts to determine the cause) significant damage to the device might be the result. Magic smoke is almost always the result. |
#7
That's entirely anecdotal, mind. |
#8
If the wires were truley just connected and then powered up on the motor side they should actually be fine as long as no commands for driving were sent to the controller. Not saying there isn't any chance that damage occured but without activating the speed controller, there should be no real concern. Our lead mentor uses Victors frequently and his response to this situation was to shrug his shoulders and say "it's fine"
#9
Al- I've never seen the schematic and doubt that I could fully interpret it if I did so I'll concede there is no specific engineered protection in the design. That being said, I still believe there is an inherent tolerance to this condition in the design of the controllers, whether intended by the designer or not.
I would run them during testing and so long as everything works fine, run them in competition. Just be weary that if you begin to have trouble at the competition that there is a possibility it is due to a damaged controller. |
#10
Fox et al,
It is my firm belief that if you want to play on Einstein, you must have good engineering practice. That being said you believe what experience tells you and don't leave anything to chance. You don't wait for a failure to occur, you anticipate and replace when needed. It is for this reason we solder our crimp connections, keep spares handy and plan for easy replacement of everything in the field. Murphy is alive and well, why encourage him? |
#11
So fox, please feel free to make that value judgement for your own team, but please hesitate to make it for other teams without making them fully aware of the risks they are assuming. Covering the real risks and real costs does them a disservice. |
#12
Well I know none of my teams can afford to go out and buy a brand new fleet of speed controllers, let alone in the last week of build.
Everyone has different definitions of good engineering practice. I detest the "replace and toss it" mentality. I would argue that "Test and replace if necessary" is an excellent engineering practice and is that which is respected far more often in the real world. In today's society, everyone is too ready to throw out an otherwise perfectly good component in favor of something that is *new*. I personally have a big problem with this kind of "disposable" thinking. Should they replace them? Sure- if they are worried, have the money and time- might as well. Is replacement definitively the *one and only right* thing to do? No. |
#13
I work for a TV station in the third market of the US. I would be fired for taking that attitude. Failure of a component that was thought to be suspect that results in a loss of air time is unforgivable in my line of work. We recently replaced a $35K output tube on the transmitter for fear it would cause a loss of air time based on a several factors it exhibited in operation. One of which is a nearly two day replacement time window. While the tube tested fine, there was enough doubt in it's continued operation that the decision to replace was made. Mark, Good luck! |
#14
When I post to this forum I don't expect anyone to take what I have to say as fact. It is their responsibility to determine how much or how little of my or anyone else's advice they decide to follow. This Thread has covered all of the risks and gambles associated with this issue. Presenting an alternate solution is by no means a disservice. |
#15
I'm going to second that the Victors probably aren't too badly hurt by this, depending on how long the were run like this. If the motor wasn't under load, it was mostly running at the free-speed current of a couple of amps. I don't have a schematic for the Vics, but everyone thinks Jags are wimpier, so I'll start there...
One of the FETs has a 4mOhms on resistance, so it'd be dissipating about 1.6W under normal conditions. The diode has a 1.0V drop, so it could handle 1.6A and generate the same thermal load. Which means you could run 3.2A backwards through the Jag and it'd be about the same as a 40A load normally. So I think the vics would be relatively fine if you hooked them up backwards and didn't try to run them, provided your motor wasn't under a significant load. EDIT:That said, Eric and Al are right that it's no longer an entirely trustworthy part once you've taken it out of spec in some fashion. If I were a cash-strapped team I'd use it and try to be prepared for it failing on me. If I had the opportunity to replace it, I'd permanently brand it questionable and slap it on the practice bot. Last edited by Kevin Sevcik : 15-02-2012 at 12:09. |
