Go to Post Mentors are here to guide and explain not to decide and do. - Fe_Will [more]
Unread 13-02-2012, 12:38
mtnteam mtnteam is offline
3747 - Programmer
AKA: Steven
FRC #3747 (ChaoTech)
mtnteam is an unknown quantity at this point
Encoder Help.
I have an encoder hooked up along with a motor. The encoder reads the motor fine. But, I'm stuck on how to use the the output of the encoder with the motor. So lets say i press button 10 on the joystick. Than it tells the motor to only spin 1/4 a rotation, or 90 degrees. I've been trying every possible idea that i had. Any help is greatly appreciated.
//EDIT\\
I've noticed that In my Driver Station the VOLTS are not updating it stuck at 17.5 VOLTS or something like that. any ideas?
Unread 13-02-2012, 12:58
Re: Encoder Help.
Use a PID (or any other feedback controller) with encoder signal as process variable, and the setpoint established as follows:
Every time the leading edge of a button press is detected, increment the setpoint by 90 degrees.
What are you using this for?
Unread 13-02-2012, 13:59
3747 - Programmer
AKA: Steven
Re: Encoder Help.
I'm using it for, to feed a ball to a shooter. Is there a example picture you could show me?
Unread 13-02-2012, 14:45
Re: Encoder Help.
Picture of what? PID? It's a vi in your FRC LabVIEW installation.
How to detect leading edge of a button press?
http://www.chiefdelphi.com/forums/sh...30&postcount=3
Unread 13-02-2012, 15:40
3747 - Programmer
AKA: Steven
Re: Encoder Help.
an example on how the pid's are used with the motor.
Unread 13-02-2012, 16:34
Re: Encoder Help.
Did you search the LabVIEW help and examples, and could not find what you need?
Unread 13-02-2012, 17:10
3747 - Programmer
AKA: Steven
Re: Encoder Help.
Correct. There is a Encoder with a motor example. But all its doing is reading the motor. I want to figure out how to use that information to set it so many turns or degrees.
Unread 13-02-2012, 17:12
Re: Encoder Help.
I don't know what you mean by "reading the motor". Could you explain.
Is there an example that shows how to control motor position using a PID?
Unread 13-02-2012, 18:28
3747 - Programmer
AKA: Steven
Re: Encoder Help.
I'm not seeing one at all. So i was wondering if you have an example you could show me.
