Go to Post I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way. - bfk [more]
Unread 17-01-2012, 18:08
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Updating Jaguar Firmware
So... I'm having trouble updating the frimware for the jaguar. My team is in the process of switching to CAN. I have the update, I have the bdc-comm. THe trouble is I don't know how to get the update from the computer to the jaguar. What kind of port do I need to have the jaguar plugged into?
Unread 17-01-2012, 18:15
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
Re: Updating Jaguar Firmware
See this link.
Unread 17-01-2012, 19:28
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
You must make the rj12 to db9 converter provided in the kit. Then plug the db9 into a computer and the rj12 into the jag
Unread 17-01-2012, 19:35
Lead Programmer
AKA: Josh
So...
The issue was that I was using a db9 port. Now I'm using the Serial port.
However, when I try to update, I get the error message "Unable to contact boot loader." I'm at a loss as to what I need to do.
Unread 17-01-2012, 19:43
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Make sure you have the right COMM port selected in the upper left hand window of the BDC-COMM Tool. When you are connected to the jaguar you should see a firmware version and other indicators that you are connected properly. If you think you have the right port selected than it may be a problem with your terminator resistors or wiring setup. Make sure you can communicate with the Jaguar before trying to update the firmware.
Unread 17-01-2012, 19:51
Lead Programmer
AKA: Josh
THere's only one com port that is available to choose. The firmware version is 0, which I know can't be right. I've checked the wires and the terminator, and they both seem to be done correctly.
Unread 13-02-2012, 19:30
Thundrio Thundrio is offline
Dedicated Racer
FRC #3673
Thundrio is on a distinguished road
I am having the same issue (I am trying to update the jags firmware to be able to use the auto ramp feature). I have connected it, but when I run BDC-COMM it does not recognize that there is a jaguar hooked up, but if i plug it into the other port (which is the opposite of what was linked earlier tells you to do) then it displays everything as 0 and when I try to update firmware it displays the before mentioned error).
The only thing I can think of that would cause this is that it says to use BDC-COMM.exe but the only thing I found to download (after a long time searching ti.com) was bdc-comm-92.exe
TYIA
Interested in a new way of playing old games?
visit http://www.speedrunslive.com for a way to make single player games multiplayer!
visit http://www.zeldaspeedruns.com to open up a new world for zelda lovers!
pm me here or at zsr for more information!
Unread 13-02-2012, 19:45
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Go Here
Down load the 2012 BDC com program. The 2012 jaguar firmware. Currently version 101. This will be a zip file. Unzip it. The 2012 getting started guide. The Jaguar getting started guide. Particularly how the serial cable adapter needs to be wired. These explains what needs to be done far better than I can.
Unread 13-02-2012, 20:46
Dedicated Racer
FRC #3673
As far as I am aware, everything is connected completely. On the Jag getting started guide it says when bdc-comm is open the jag should be solid yellow (which it is not). It says to then check connections (which i have multiple times) and then possibly change com port. when I try to change the com port in bdc comm (by clicking on it), it just gets highlighted and no option to change appears.
TLR the guide says to change com port, but I cannot change it from one
Unread 14-02-2012, 00:07
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Have you guys made sure that 1) the pins in the Jaguar port are contacting the CAN cable and 2) you have a terminator plug in the CAN?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 14-02-2012, 09:53
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Assuming you are using the adapter that comes is the kit of parts....
It need to be wired per the getting started guide. Just plugging the wires in logical holes will not work. Do not forget the resistor although that has nothing to do with the RS-232 side of things. Make sure you are using a straight wired 6 wire cable. A lot of the premade canbus cables are 4 wire which will not work for the cable to the computer or CRIO. Try Ohming out the cable be sure everything is wired right.
If you only have one com port on your computer, the BCD will only have that for an option.
If you are running win7 64 bit, try running in XP mode. It may not run in 64 bit.
The solid yellow LED means the Jag is getting a 0 speed command. A logical consequence of everything connected correctly.
