Go to Post You'll want to start with P, add some D to help prevent overshoot, and then add some I to help it get to the correct height if it isn't there from the P and D. - AustinSchuh [more]
Unread 13-02-2012, 17:16
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Watchdog Not Fed -- Ghosting
When we run the robot we get "Watchdog Not Fed" errors and the robot 'ghosts' every now and then. What do I need to do to fix this problem?
Unread 13-02-2012, 18:39
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Re: Watchdog Not Fed -- Ghosting
we are also having the same problem so if you can figure anything out that would be great, our only guess it that the our vision processing is taking up alot of the memory.
Ferris State University-Manufacturing Engineering (BS)
FRC 2054: Student 2010-2013
FTC 6283: Mentor 2012-????
FTC 5980: Mentor 2012-????
FTC 7837: Mentor 2013-????
FRC 2054: Mentor 2013-????
FRC 5162: Mentor 2014-????
FRC 5448: Mentor 2016-????
FRC 5576: Mentor 2015
Unread 13-02-2012, 18:56
dmitch's Avatar
We are not using vision processing, we have a very basic setup. Everything in our code at this point is very simple control of drive, and 5 other motors for our robot.
Unread 13-02-2012, 20:32
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Note that we have timed our vision processing code which is based on the 2012 vision sample code, all the filtering takes up between 150 to 200 msec. So if you are calling that code in your main robot task, you need to make appropriate adjustment to your watchdog expiration time.
Unread 14-02-2012, 01:49
Are you running wireless or with a physical ethernet connection? We had a serious episode of robot glitchiness yesterday that got better when I manually changed the D-Link's WiFi channel to one that didn't have quite so many other networks on it. (I used the inSSIDer program to show me nearby wireless networks.)
