Go to Post As to "no fasteners," I have a gallon of epoxy, and I'm not afraid to spread it. - Rick TYler [more]
Go Back   Chief Delphi > Announcements
Unread 13-02-2012, 07:41
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
TrafficCop
Introducing TrafficCop, a signaling device for robot/driver cooperation, useful for FRC 2012 and beyond.
Imagine you are balancing on a bridge at the end of the match. How do you communicate with your alliance partner on the other side of the corral, or to the opposing alliance across the field? With TrafficCop, you direct them to stay still or move to adjust the balance.
Features:
Black 4" x 4" circuit board for high contrast.
Bright red and green LEDs, or build with your own.
Operates from 1 Spike relay module or two 12V solenoid drivers.
Can be daisy-chained with standard PWM cables to run multiple units from the same power control (not included).
Square board may be mounted upside-down to reverse arrow polarity, or at 90° to signal forward/back.
On-board PTC resettable fuses to protect against shorts.
Through-hole components for easy modification or kit assembly.
Available fully assembled, as a kit for you to solder, or as an empty black PCB.
Learn more at http://www.auroraresearch.com/.
Brandon Martus
e-mail
Unread 13-02-2012, 12:34
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: TrafficCop
Nice design!
Unread 13-02-2012, 20:50
savage24x savage24x is offline
AKA: Kendrick Grace
FRC #2590 (Nemesis)
Team Role: Student
savage24x is a jewel in the roughsavage24x is a jewel in the roughsavage24x is a jewel in the roughsavage24x is a jewel in the rough
Re: TrafficCop
How would the other teams be signaled? You place this on the side of the robot? You obviously wouldn't hand one out to each team...
Unread 14-02-2012, 01:08
nitneylion452's Avatar
AKA: Joe Lee
Re: TrafficCop
This would be on the robot. Light up what you want the other robot to do.
I really like this design.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
