Go to Post "Magnificent" is the only appropriate adjective for a handlebar moustache. Kudos. - Lil' Lavery [more]
Unread 04-01-2003, 20:29
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
Cool PBASIC Conversion
Since the default code is not valid, I went ahead and converted it to "old style" PBASIC 2.0c. I don't have anything to test it on tho, so someone please check me here.
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Unread 04-01-2003, 20:33
cybermind cybermind is offline
#1046 (PRISM Robotics)
cybermind is an unknown quantity at this point
Send a message via AIM to cybermind
I tried to tokenize it on the BASIC Stamp Editor 1.33 and it works just fine after the following changes:
Delete the '{$PBASIC 2.5} line
Put the SERIN on one line
Put the SEROUT on one line
After those changes it Tokenized successfully.
Unread 04-01-2003, 20:39
Noah's Avatar
Code Monkey
Oh, ok... in that case the default code is much nicer than mine. Glad to hear that.
Unread 04-01-2003, 21:08
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Ummm... how? It still complains about the missing labels after the "then" in all the if statements and it has no idea that the word select is supposed to be a command.
Noah: Nice work. You probably want to nuke that darn $PBASIC 2.5 directive, though. It just isn't valid as far as I can tell. Also, if you want to test, go ahead and drop it in RoboEmu. Available at my website: http://www.robbayer.com/software.html
Unread 04-01-2003, 21:10
NOOOO!
I didn't get the Default to work....I got Noah's to work after the changes...I probably should have been more specific. Hey, I'm a rookie, so that's ok
Unread 05-01-2003, 01:28
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
It looks to me like there is a new version of the BASIC Stamp Editor or tokenizer which recognizes the $PBASIC directive, and makes the if...then...else...endif and select...case...endselect syntax valid.... I just haven't been able to find it yet.
Unread 05-01-2003, 10:30
Goya Goya is offline
#0019 (Big Red)
Goya is an unknown quantity at this point
Send a message via AIM to Goya
In fact, parallax.com offers a new commercial software version for the basic stamp editor. Version 1.5!
Could it be that this editor supports the PBASIC stamp?
Could it be that the PBASIC stamp was meant to read 1.5 and not 2.5?
BTW - the new editor is much more "spruced" up. I didn't notice any new commands, since the default code did not work, with the same errors as the other editors.
FYI - Also, RoboEMU complains about the serout command.
Unread 05-01-2003, 12:17
Chris_C Chris_C is offline
None #0131
Chris_C is an unknown quantity at this point
Send a message via AIM to Chris_C
I heard by word of mouth on Friday from two Innovation First guys that a new release of the parrallax software that fully supports all the new commands can be expected within a day or two. I don't know if that is still true, since they seemed to think the release would be happening yesterday or the day before. They didn't mention any version numbers, so I can't help you there.
Unread 05-01-2003, 12:48
iscrc2 iscrc2 is offline
#0568 (Nerds of the North)
iscrc2 is an unknown quantity at this point
This post on the parallax yahoo forums http://groups.yahoo.com/group/basicstamps/message/27596
makes it sound like parallax will be a few weeks (mid/late January) until they release the new version.
Unread 05-01-2003, 20:28
Are you referring to CodeDesigner BSE? I can tell you that it does NOT support PBASIC 2.5 as I have the demo version and have tried to get the new syntax to compile. No luck.
As for RoboEmu, it will complain because the Serout isn't all on one line. It doesn't complain about the rest of it because it is currently setup to ignore commands it doesn't recognize (ie SELECT, etc). This meant I didn't have to add support for commands like HIGH and LOW.
Anyway, I'm in the process of updating RoboEmu as we speak and it should support all the new constructs, but I'm going to need help testing it. Look for 1.09 within 24 hours of the official release from Parallax.
Unread 07-01-2003, 23:33
Noah's Avatar
Code Monkey
For clarification, innovationfirst's site now tells us that a PBASIC 2.5 editor is expected to be available on the 10th. They also have posted 2.0 valid PBASIC default programs.
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Need to learn PBASIC...Where Should I Go? IMDWalrus Programming 5 29-04-2003 16:43
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
PBasic Question Melissa H. Programming 28 17-11-2002 18:53
