Go to Post Duh! Sometimes the simplest answers are the best ones! - dlavery [more]
Unread 13-02-2012, 22:21
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Keeping polycord on track
For our collector, we are using a polycord based system on PVC rollers. Because the PVC is not sticky enough, we are using silicon caulk in between our pulleys. Our system relies on bent aluminium rails to push the ball to the center and the section that rises it to the shooter. However, when the ball enters off center, it pushes the polycord off, as seen in the picture. We tried adding some flat belting, but it only exaggerated the problem, getting more pushed off than the polycord. We don't have a terrible lot of experience with polycord, so I would be very appreciative if someone could point us in the right direction.
Unread 13-02-2012, 22:45
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: Keeping polycord on track
Are your grooves deep enough?
Ours doesnt have that issue. But then again, our balls are guided by polycarbonate sheets on the other 3 sides.
Unread 13-02-2012, 22:47
578robotsrock's Avatar
578robotsrock 578robotsrock is offline
I belive robots rock!
AKA: Erich
FRC #0578 (Red Raider Robotics)
578robotsrock is on a distinguished road
I would agree, make sure grooves are deep enough.
I BELIEVE THAT ROBOTS ROCK
Unread 13-02-2012, 22:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We tried having guides move the balls sideways in our conveyor, on our prototype. It didn't work, as you see. We ended up putting the ball centering guides below the conveyor, on the bottom of the robot, so the ball moves sideways as it's in contact with the lower roller, then the balls go straight up. Works good.
Kinda late for this info....
Unread 13-02-2012, 23:00
waialua359's Avatar
AKA: Glenn
Are the polycords skipping as you drive the robot?
I could see it doing this if the ball is moving in a different direction in relation to the ground.
In other words, are you able to add something to your robot to limit ball movement perpendicular to the cords?
Unread 13-02-2012, 23:03
AKA: Simon Bohn
We've got a bottom plate that the ball gets pulled on, so the movement of the ball is independent of that of the robot. It is made of perforated aluminum, so that may be causing some problems. Maybe coating it in something slippery might help? (And by that I don't mean oil, I mean something like teflon)
Unread 13-02-2012, 23:08
Borobo Borobo is offline
AKA: Patrick
FRC #0159 (Alpine Robotics)
Team Role: CAD
Borobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really nice
is your polycord tight enough? we have each of our strands of polycord under about 20-25 lbs of pressure and we don't have any of these sorts of issues
Unread 13-02-2012, 23:13
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Three things:
1. It really helps to have a reaction surface just behind the belt on longer belt runs. This stops the belts from distorting to the point of hopping belt guides and such.
2. Flat belts do not run well on a flat roller. You need a PVC ring or something for it to center itself on. It's counter intuitive I know. However, because the larger diameter PVC ring's surface velocity is higher then the slightly smaller diameter roller the flat belt will center itself so long as it is touching the PVC ring. Alternitively, the way you have it, the flat belts will always want to ride up the round belts guides.
3. I suggest not mixing flat and round belts so the above won't happen. It can be done. However, there usually isn't any real advantage to it.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 13-02-2012, 23:22
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
You can also consider making a "comb" or guide to mount along the run to constrain the polycord, traditionally we have placed one near the motor if we are using a polycord band off a pulley to drive the rollers. Just make sure you smooth the edges so it doesn't shred the cord.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
AKA: Simon Bohn
Yeah, we're getting rid of the flat belt, it was just a test to see if it would help. The idea of a reaction surface is an interesting one, it might be worth making one up.
Unread 13-02-2012, 23:32
Joe Schornak's Avatar
Joe Schornak Joe Schornak is offline
No Stranger To Love
FRC #2840 (Blue Tide)
Joe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to behold
We had a similar issue until yesterday. As the ball reached the end of our intake track, it would push the polycord out of its groove. We determined that this was happening because the curvature of the ball was pushing the cord to one side or the other, which caused it to hit the edge of a groove at an angle when the ball reached the inner roller and pull out of place. Judging from your picture, it looks like the middle loop is being significantly pulled to one side, which may be one of the causes of this issue.
Somewhat counterintuitively, loosening the troublesome loop relieved the problem. We ended up completely removing it in the end, since the intake worked just as well with two cords rather than three, but I do not know how this would affect your design.
Also, the process of pulling the ball against an angled rail could be pushing your cord. In my experience, the balls have significant grip against many surfaces, so you could try putting a slicker surface where the ball would contact. We have used teflon tape in similar applications with positive results.
Let us know if you have any further issues, and have a most excellent final build week.
1. Acquire Manual
2. Read Manual
3. ???
4. PROFIT!
Visit www.pcdsrobotics.org!
Unread 14-02-2012, 07:57
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
We're using a similar pick-up system, and had the same problem. Even made our rollers the same way you did. The ball needs to be able to roll against your side guides.
Put some PVC "rollers" over your guide rails, like you see in the cad model below. That simple fix made ours work unbelievably well!
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 14-02-2012, 08:58
LH Machinist LH Machinist is offline
LH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura about
Use a belt length calculator http://www.durabelt.com/beltlengthcalculator.php
You’ll be surprised about how tight they are supposed to be. The “normal” stretch factor is between 8% – 12%.
Unread 14-02-2012, 09:03
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
we were having the same problem last night with poly cord.
Is the tension on the bottom alot or just enough and i saw u said u used pref rated aluminum have u tried lexan because thats working well for us and reduced the tension
Unread 14-02-2012, 09:12
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
It either looks like you might have too much squeeze on the ball as it travels up your elevator or that your cords are spaced to far apart.
I would try placing some sort of backing behind the cords or I've seen teams use a strip of lexan as a backing with zip tie loops (not tight, just loosely placed) to keep the cords in place.
