Go to Post There was a manual? - Taylor [more]
Unread 13-02-2012, 20:44
cooltext cooltext is offline
FRC #0835
cooltext is an unknown quantity at this point
Encoder wiring
So I have the AS5030 8-bit Programmable Magnetic Rotary Encoder but I don't know how to wire it. When I am coding (in java) it requires 2 channels, but the board that we got only has one 3 prong connector coming out, does anyone know how to wire this?
Unread 13-02-2012, 21:20
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Taylor Hawkins is an unknown quantity at this point
Re: Encoder wiring
Are you using the Encoders that go on the shafts of the Cimple Gearboxes that came in the kit? If so this is what we did, if Not were using different encoders.
There are 4 wires coming from the encoder. +5v, ground, and signal A and signal B.
These are all wired to the Digital I/O of the digital sidecar. The 2 signal wires will go into separate ports in the digital sidecar.
Unread 13-02-2012, 22:21
FRC #0835
Re: Encoder wiring
No, we are using the demo board that comes with the AS5030 8-bit Programmable Magnetic Rotary Encoder. I am looking on how to wire the two output channels
thanks
Unread 13-02-2012, 22:30
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Encoder wiring
According to this documentation http://www.usfirst.org/uploadedFiles...ual%20Rev1.pdf
there is only one signal wire used according to page four when outputting a PWM or analog value. Two wire is DIO, CLK. The encoder in the WPIlib is meant specifically for thr E4P optical encoder since that one needs two signal wires as a quadrature encoder.
Unread 13-02-2012, 22:34
FRC #0835
Re: Encoder wiring
So how could I use this encoder in a PID loop(we are using java, but any language should be okay). We are try to track the RPMs of a spinning axle.
thanks
Unread 13-02-2012, 22:42
MagiChau's Avatar
AKA: Michael Chau
Re: Encoder wiring
Read the documentation I have linked to. This encoder relies on a magnet mounted to a rotating shaft being really close to it (0.5mm to 2.0mm) so I am not sure if you can even properly set this up depending on what is available. The code itself depends on which signal type you wish to use.
Unread 13-02-2012, 22:47
FRC #0835
Re: Encoder wiring
I read the documentation. Could you go into detail on how to program the encoder into a PID loop. Right now I have it as an AnalogChannel, but I don't know how to get the rate from that. How do I get rate, like rpms?
thanks
Unread 13-02-2012, 22:56
MagiChau's Avatar
AKA: Michael Chau
Re: Encoder wiring
I am not experienced with these encoders so I cannot help you that much. According to the documentation you would have to be able to count every time the voltage changes from 5V to 0V or vice versa (full rotation.) Rate if I am thinking correctly would be change in counts (since last count measurement) divided by time (since last count measurement) for this encoder not accounting for error. There is a thread dedicated to Speed based PID Control Loops if you search for it.
Unread 13-02-2012, 23:58
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Encoder wiring
Partially right, partially wrong. The WPIlib Encoder class is designed to handle any quadrature encoder; the E4P is just standard to use in FRC due to USDigital's sponsorship.
You might be able to use the gear tooth counter class for this encoder.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 14-02-2012, 19:56
FRC #0835
Re: Encoder wiring
How do I wire the AS5030 encoder for high rpm uses, like 4000 rpms?
