Go to Post I know our driver is going to nats over the prom. I mean come on, who wouldnt? :D - karinka13 [more]
View Poll Results: Are dumpers better than shooters?
Yes 11 8.66%
No 64 50.39%
It depends if the dumper is quick and accurate 52 40.94%
Voters: 127. You may not vote on this poll
Unread 13-02-2012, 01:06
ttldomination's Avatar
Sunny
Re: Team 3528 Robot
Ew, a scissor lift.
Cool, one that actually works.
Legit, this thing looks solid. I would take care to really strengthen that thing up. Nothing shows the fragile nature of scissor lifts like taking a head on collision with a 120 lb robot.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 13-02-2012, 01:15
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Team 3528 Robot
I really believe it depends on if the dumper is quick and accurate. If a shooter and a dumper take the same number of shots and the shooter's going for top hoop and the dumper's going for middle... the shooter just has to make 2/3 shots or better to outscore the dumper (assuming the dumper is 100% accurate).
Lets say a really good shooter is close to 100% accurate as well, well then the dumper has to outpace the shooter and get 3 baskets per the shooter's 2 to stay even with them.
It's a pretty interesting situation to me. Esspecially if alliances use ball management strategies or passing/feeding. Two robots feeding balls to an accurate 3 pt shooter or 3 robots gathering and taking as many shots or dumping as much as each can...
Unread 13-02-2012, 01:25
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a name known to allfrasnow is a name known to allfrasnow is a name known to allfrasnow is a name known to allfrasnow is a name known to allfrasnow is a name known to all
Re: Team 3528 Robot
I really liked your team's defense strategy last year, but it's great to see 3528 transition to a legit scorer in its second season.
Unread 13-02-2012, 16:57
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Team 3528 Robot
My! It's good to see team 3528, UPNEXT back and a bigger threat than ever! . Best of luck to you guys from Team 1710! And a personal gesture from me . I'm sure you guys are well on your way training with drivers and will have the routine down to 10 seconds flat! Hope to see you guys again this year! Good luck!
Unread 13-02-2012, 23:33
TeamUpNext3528's Avatar
TeamUpNext3528 TeamUpNext3528 is offline
FRC #3528 (Team UpNext)
Team Role: Driver
TeamUpNext3528 is an unknown quantity at this point
Re: Team 3528 Robot
Originally Posted by ttldomination View Post
Ew, a scissor lift.
- Sunny G.
The scissor lift is pretty strong. It doesn't wobble much when it get hit hard, so we are happy with it. Its very accurate and durable.
Unread 13-02-2012, 23:36
Andrew Lawrence
Posts: n/a
Re: Team 3528 Robot
Make sure that your scissor lift is too strong, and what's on top is never too heavy. 256 had a scissor lift a few years back. It was the heaviest part of our robot, and our electronics were right underneath it. We got hit pretty hard, and our scissor lift broke, the part it lifted fell, and I think you can figure out the rest. :|
Unread 13-02-2012, 23:41
Team Role: Driver
Re: Team 3528 Robot
Thanks so much! We can't wait to see all our friends especially 1710! We are so excited to play again and are so pumped to compete. What are you guys doing with your robot??
Also, thanks frasnow!
Unread 13-02-2012, 23:43
Team Role: Driver
Re: Team 3528 Robot
Oh yeah its definably not to light. We have made sure that is not to heavy because the worm gear needs help lifting it up. We are actually 0.8 lb over, so we are going to cut some of the dumper down.
Unread 13-02-2012, 23:45
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Team 3528 Robot
The only thing I worry about is you guys getting pushed around a lot while trying to score with those mechanums. Speaking from personal experience, (68 had mechanums last year) I can tell you that any robot with 6/8 wheel drive is going to shove you all over the place.
Besides that the robot is great! We'd never go with a scissor lift as they have to be made perfectly, but it looks like you guys knocked it out of the ball park.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 13-02-2012, 23:57
Team Role: Driver
Talking Re: Team 3528 Robot
Thats very true, mechanism are not the best for traction. We did want a robot that could move around quick and get balls fast, so it depends what the other "defender" robots have for a drive train.
Thanks so much! This is our teams second year and our first time doing a scissor lift. Good luck to you all!
Unread 14-02-2012, 00:04
JosephC's Avatar
Re: Team 3528 Robot
Emphasis mine. Sorry to be a grammar hound, but I do believe it's Mecanum.
(a bit OCD sorry)
Referee: 2015 - ?
Unread 14-02-2012, 00:10
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: Team 3528 Robot
Emphasis mine. Sorry to be a grammar hound, but I do believe it's Mechanum.
(a bit OCD sorry)
Sorry to pull the same, but it's spelled "Mecanum."
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 14-02-2012, 00:13
JosephC's Avatar
Re: Team 3528 Robot
Autocorrect strikes again.
Referee: 2015 - ?
Unread 14-02-2012, 00:19
Djur's Avatar
WPILib
AKA: Sam Carlberg
Re: Team 3528 Robot
It happens to the best of us.
Back to a more on-topic post: Team 2084 is using Mecanums again this year, but we won't be able to be pushed around very much (at least not like the one in this video).
Unread 14-02-2012, 00:24
JosephC's Avatar
Re: Team 3528 Robot
I'm guessing you have drop down wheels, or you have a 8 wheel mechanum crab drive.
Referee: 2015 - ?
