Re: Labveiw Issue
Notice that this is a different error then the first one. This says there's now a RefNum issue in disabled. Since things still aren't working, it would be helpful if you posted your modified code. Do you have anything else in telop? |
Re: Labveiw Issue
The error in Disabled.vi means you changed the name of your main drive motors and didn't notice that the old name is used in Disabled.vi.
Re: Labveiw Issue
I changed the begin.vi and teleop.vi motor names and made sure disable.vi had the same name (I copied and pasted). I am no longer recieveing that message in the diagnostics only saying the camera isnt hooked up (which we arent going to use this year). But, they are still not working. I also have all 6 hooked up to the jaguars that are connected to the correct PWM.
Now that I think about it, could thoes wires be incorrect? How do we know they are facing the correct way? (I hooked it up, myself, so I would know what you are talking about. We are using the ones with brown on one side and orange on the other) Thank you for all your responces. |
Re: Labveiw Issue
The robot is Enabled (it must be for the Jags to get a signal)?
An easy test for the PWM cable is to just reverse one end. If you had it backwards before, then the Jag light would go solid. |
Re: Labveiw Issue
I tried moving the wires around and i never got a solid light. Am i putting them on the wrong prongs? It says PWM out. Sig Pwr (-) The brown is at the SIG and the orange is in the PWR. They are on the 3 prong one, directly next to the double prong set.
Re: Labveiw Issue
Our team has a four motor drive, but were only using two PWM cables. Were using Y splitters for the left and right motors. You could try doing that and change the four motor to like Arcade Drive or Tank Drive. Basically back to the default.
#7
Re: Labveiw Issue
I usually make the Brown wire the power (closest to standard black for ground).
On the Digital Sidecar the ground wire for PWMs is to the outside. On the Jaguar the ground wire goes to the inside (it's marked too). Even if you got one end wrong, trying the other end in both possible orientations would make it matchup eventually. Here's a list:
#8
Re: Labveiw Issue
Thank you. The Y-Splitter worked. Now the only issue is, is that one is still not working. The belt. I had to switch it to a Victor because of an issue with a differnt jaguar and I changed it in the programming, but, even when it was a working jaguar, it wouldnt work. The wheels work, but not the belt. I dont see why it wouldn't when everthing thing else works. I even played with the PWM wires and the light never turned solid.
