Go to Post We can't turn off inspiration and recognition, development and learning with a switch. It is an on-going process. If it were not, there would be no need for CD except for 6 weeks out of the year. - JaneYoung [more]
Unread 14-02-2012, 09:22
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: pic: Team 714 week 3 robot
Have you guys had any problems with your frame twisting due to the large opening in the front? The reason I ask is that we have, although we have more cross bracing than you. We had issues with all wheels not touching the ground until we were able to loosen up many bolts, clamp down the robot on a table and tighten up everything and then it was okay.
