Go to Post Is that severed hand legal? I think it's a COTS assembly from previous years. - Taylor [more]
Unread 14-02-2012, 09:16
LH Machinist LH Machinist is offline
LH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura about
Over Weight?
http://www.matweb.com/tools/weightcalculator.aspx
Before you start cutting away you can use this calculator to find out how many holes you need to drill in 1/8" aluminum to lose a pound. One pound equates to the following:
1671 - 1/4" holes
418 - 1/2" holes
104 - 1" holes
Last edited by LH Machinist : 14-02-2012 at 09:20. Reason: forgot to add material type & thickness
Unread 14-02-2012, 09:17
Andrew Lawrence
Posts: n/a
Re: Over Weight?
This is just awesome! I can't believe someone actually made this! Thanks for sharing!
Unread 14-02-2012, 09:32
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: Over Weight?
When it comes to weight, the sort of mentality "Is the juice worth the squeeze" doesn't really apply. Every little bit counts- do you use washers on your fasteners?- you don't anymore! Can you replace a bolt with a rivet or a nylon bolt? - then do it. All these little things add up very quickly so go get your drill and a 1/2" or 9/16" drill bit and have at it! Don't forget your deburring tool.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 14-02-2012, 09:33
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: Over Weight?
We removed substantial weight with 3/16 drill holes this year, almost 8000 in total. There are also about 500 2 inch diameter holes on our robot. Total weight savings were something like 10LBS, I guess it worked as this is our lightest robot in years.
Unread 14-02-2012, 10:02
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Over Weight?
To lose some weight this year, we've started pocketing. For those unfamiliar with the term, its basically using a mill to turn thick metal into thin metal in selected areas. It looks great, and is much more effective than normal cheese holing, because you can remove a lot more metal without greatly compromising structural integrity.
Unread 14-02-2012, 10:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Over Weight?
We were kinda low on funds this year, so we didn't put any extra metal on our robot.
Unread 14-02-2012, 10:25
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Over Weight?
I would hate to be the freshman designated to deburr all those holes!
Unread 14-02-2012, 12:04
Re: Over Weight?
At 10 seconds per hole, that's 22 hours to save 2.5lbs (assuming 1/8 in alluminum). Why would you spend that much time lightening an already light robot?
Unread 14-02-2012, 12:18
fox46's Avatar
Re: Over Weight?
Because if you don't you can't compete and then you will have wasted far more than 22 hours.
Unread 14-02-2012, 12:58
AdamHeard's Avatar
Lead Mentor
Re: Over Weight?
Weight savings is far better by using lighter/less stuff than drilling holes.
Unread 14-02-2012, 13:06
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Over Weight?
Quoted for the truth.
Here is an excellent white Paper written by IKE that has some tips. http://www.chiefdelphi.com/media/papers/2220
Depending on your construction methods, some simple tricks can net you some big savings. Switch any 1/8" wall tube to 1/16" wall. You've essentially saved 50% of the weight of the tube. Go to smaller fasteners/rivets/velcro where possible. Decorative Panels and or Protective shields don't need to be 1/8" Thick Lexan where 1/16" or even thinner will suffice. Depending on the hardware you use (This is most useful when dealing with a lot of larger fasteners, 1/4-20 or above) cut any excess threads off of bolts - no need to have 1/2" of threads sticking out of the nut.
Much of that advice is taken from IKE's paper, but some if from personal experience. Your results may vary.
-Dustin Benedict
Unread 14-02-2012, 13:24
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Over Weight?
A couple of our students over the years have played ice hockey and donated their broken carbon fiber sticks instead of trashing them. Occasionally a section of it makes an appearance on a robot, just make sure it doesn't take an impact from the wrong direction!
The entire roof assembly of our Breakway bot was carbon fiber stick as the ridge with a piece 1/32 Lexan riveted to it.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
