Go to Post Are you saying you want to submerge your circuit board in an open container of liquid nitrogen? - Ether [more]
Unread 14-02-2012, 09:17
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: Keeping polycord on track
Your problem might be caused by having so much polycord. The tension of it could be causing the pvc to bend in towards the middle. This would cause lots of jumping. We experienced a similar issue in 09 so we stuck a piece of aluminum L the size of the inner diameter of our pvc through it to straighten it out.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 14-02-2012, 10:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by 45Auto View Post
Put some PVC "rollers" over your guide rails, like you see in the cad model below. That simple fix made ours work unbelievably well!
That's a neat idea!
But I think we're doing something wrong on ours, we only have one set of polycord belts, and two rollers, to do the whole harvest/lift/load-into-the-hopper thing.
Unread 14-02-2012, 10:37
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
I very seriously doubt if you're doing anything "wrong" , just make sure that multiple balls don't bind up on each other as they roll against each other.
The balls generate a lot of friction when they try to roll against each other. We've had bad experiences with single-feed systems with multiple balls binding up which led to our "dual lift" design with cords on front and back where the balls don't roll against each other.
Your system probably works better than ours if it's engineered correctly!
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 14-02-2012, 10:40
MrForbes's Avatar
AKA: Jim
No, we do have the problem with multiple balls being able to easily jam in the intake. It's neat to see how you solved that problem.
The main reason we don't have much stuff on our robot, is because we're lazy....we'll spend hours figuring out how to avoid making more parts!
Unread 14-02-2012, 11:07
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by LH Machinist View Post
Use a belt length calculator http://www.durabelt.com/beltlengthcalculator.php
You’ll be surprised about how tight they are supposed to be. The “normal” stretch factor is between 8% – 12%.
In FRC applications, you only need 3-4% stretch.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-02-2012, 11:17
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
We just put our polycord on last night and it didn't seem to have a problem. We're using pvc rollers wrapped in shelf liner which creates enough friction that the belts don't move side to side.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
