Go to Post The season ended. Not cool. - Koko Ed [more]
Unread 14-02-2012, 01:18
lemonzap lemonzap is offline
Head Programmer
FRC #2928 (Viking Robotics)
lemonzap is on a distinguished road
problems with small Crio
We got a new 4-slot Crio this year but its been acting weird. We constantly have to reimage the Crio because we will stop being able to connect to it, but everytime we lose connection reimaging fixes the problem temporarily. Has anyone else had this problem or know a way to fix it?
Unread 14-02-2012, 10:38
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: problems with small Crio
Stupid question, but are you running CAN?
Unread 14-02-2012, 10:42
Does the problem show up when you try to download new code AFTER you've downloaded code at least once?
Unread 14-02-2012, 20:31
Head Programmer
We are not running CAN and the problem doesn't happen after any recognizable pattern. it may be the first time we deploy code to it or the 5th, it doesn't matter.
Unread 15-02-2012, 02:11
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
Check that your cRio is electrically isolated from ground. I recall reading a similar problem a week ago and it was caused by a bolt holding the cRio grounding it to the frame.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Unread 15-02-2012, 07:45
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
What's the CPU load as reported by the Driver Station?
I'm guessing that you're using 100% or close to 100% CPU. This used to be very common when teams would use the whole CPU, as the bootloader (which runs in a lower priority) would not be able to run (thus you become unable to download code, at least in LabVIEW).
We used to fix it by flipping the "No App" DIP switch, rebooting, downloading, then un-flipping the switch and rebooting again. However, with the lack of DIP switches, we will be out of luck.
Kettering Motorsports
Unread 15-02-2012, 12:14
joe5joe7's Avatar
joe5joe7 joe5joe7 is offline
Head of Programming
AKA: Joseph Kaiser
joe5joe7 is just really nicejoe5joe7 is just really nicejoe5joe7 is just really nicejoe5joe7 is just really nice
I am another programmer on Lemonzaps team, and I suspect this might well have been the problem. The board we were using has since been dismantled, but I will make sure that the new board won't have that issue.
Hope that was the problem!
Unread 15-02-2012, 23:34
Head Programmer
I talked to rob and he pointed out that "our electronics board was on polycarbonate so it couldnt have been the problem."
