Go to Post its like the championship being ice cream, its pretty awesome IRI is like adding toppings, making it even more awesome - Aren_Hill [more]
Unread 14-02-2012, 11:16
mtnteam mtnteam is offline
3747 - Programmer
AKA: Steven
FRC #3747 (ChaoTech)
mtnteam is an unknown quantity at this point
Volts.
the VOLTS output on my driver station, is not being updated. It's stuck at about 17.5 volts.
Unread 14-02-2012, 11:46
Re: Volts.
Are you in compliance with [R64]?
Unread 14-02-2012, 12:02
Re: Volts.
... and [R36] paragraph 1
Unread 14-02-2012, 12:09
3747 - Programmer
AKA: Steven
Re: Volts.
Okay great ill try it out. I have found this - http://frc-manual.usfirst.org/viewSingleItemMap/705
is that what your referring to?
EDIT:
We do have this installed and setup. Still have no volts.
Unread 14-02-2012, 13:13
Re: Volts.
Try a different analog breakout. That sounds like the reading you'd get if one of the resistors in the battery sense voltage divider is open or missing.
Unread 14-02-2012, 14:08
3747 - Programmer
AKA: Steven
Re: Volts.
okay we will try it.
Unread 14-02-2012, 14:14
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Volts.
I ran into a team with this issue during an inspection last year. It was discovered that they wired the 24V from the PD to the analog bumper instead of the solenoid bumper. I believe that they had pulled the cRio as part of thier witholding and accidentally swapped the connectors when reinstalling it.
Mark
Brick walls are for other people. - Randy Pausch
