Cannot re-install Windriver (Vista x64) screenshots inside.
Basically we uninstalled in an attempt to fix an issue and we now cannot re-install it. After inserting disk 1 and beginning the installation, we get the following errors:
http://imgur.com/a/yrHvI Is there any way to fix this issue? |
Re: Cannot re-install Windriver (Vista x64) screenshots inside.
So what does the .log file it tells you to look at say?
Sorry, forgot about that. It's basically just what the third panel had as far as I know. <?xml version="1.0" encoding="windows-1252" standalone="no"?> <!DOCTYPE log SYSTEM "logger.dtd"> <log> <record> <date>2012-02-14T19:30:30</date> <millis>1329247830606</millis> <sequence>0</sequence> <logger>com.windriver.installer.services.logging </logger> <level>SEVERE</level> <class>com.windriver.installer.controller.internal .ishield.InstallShieldOutputHandler</class> <method>notifyDone</method> <thread>10</thread> <message>InstallShieldOutputHandler:notifyDone procesExitValue is 4, error message is InstallShield process can't start due to corrupt install image. </message> </record> <record> <date>2012-02-14T19:30:31</date> <millis>1329247831207</millis> <sequence>1</sequence> <logger>com.windriver.installer.services.logging </logger> <level>SEVERE</level> <class>com.windriver.installer.ui.internal.wizard. WRIStandardInstallPage</class> <method>done</method> <thread>10</thread> <message>An exception occurred during installation of an install set</message> </record> </log> |
