Go to Post [A screen shot] is very helpful - I've sent Brandon many of those the various times I've broken ChiefDelphi.com! - Jessica Boucher [more]
Unread 14-02-2012, 14:41
Team2246's Avatar
Team2246 Team2246 is offline
AKA: Jon Mardyla
FRC #2246 (The Army Of Sum)
Team2246 is an unknown quantity at this point
C++ MotorSafetyHelper
Hello,
We are having problems with the cRIO rebooting, we have narrowed it down to being a problem with the new MotorSafetyHelper. The cRIO works with the BulitinDefaultCode, but this years code has issues it seems. We tried our last years code and it had the same issues. Last year it worked fine, so it makes us think that the problem lies with MotorSafetyHelper. Thank you very much for any help you can provide. Below this years code, and information you can provide about MotorSafetyHelper would be great.
 Jon Mardyla
 2012
 FIRST ROBOTICS
 TEAM 2246 - ARMY OF SUM
#include "WPILib.h"
DriverStationLCD *dsLCD = DriverStationLCD::GetInstance(); // create the instance of a driver station
const float AutoSpeed = .5; // robot speed (movement during auto mode)
const float Stop = 0;
const float CSspeed1 = .25; // speed for the auto cannon on 1st set of auto modes(1-3)
const float CSspeed2 = .5; // speed for the auto cannon on 2st set of auto modes(3-6)
float CannonSpeed = .5; // cannon speed for
class ArmyOfSumRobot : public IterativeRobot
	DriverStation *Ds; //Driver Station
	RobotDrive *MyRobot;
	Joystick *DriveStickLeft; // Controller 1 (Left Drive)
	Joystick *DriveStickRight; // Controller 2 (Right Drive)
	Joystick *Xbox; // Controller 3 (Shooter)
	Jaguar *DriveLeft;
	Jaguar *DriveRight;
	Victor *Cannon;
	Victor *CannonHeight;
	Victor *CannonDirection;
	Solenoid *CannonFeedOut;
	Solenoid *CannonFeedIn;
	Solenoid *BridgeArm;
	DigitalInput *HeightUp;
	DigitalInput *HeightDown;
	DigitalInput *LeftKaren;
	DigitalInput *RightKaren;
	DigitalInput *AutoSwitch1;
	DigitalInput *AutoSwitch2;
	DigitalInput *AutoSwitch3;
	Ultrasonic *WallDistance;
	Gyro *ShooterAngle;
	Compressor *compressor;
	Timer *timer;
public:
	ArmyOfSumRobot(void)
		Ds = DriverStation::GetInstance();
		MyRobot = new RobotDrive(1,2);
		Xbox = new Joystick(2);
		Xbox->SetAxisChannel(Joystick::kTwistAxis, 3);
		Xbox->SetAxisChannel(Joystick::kXAxis, 1);
		Xbox->SetAxisChannel(Joystick::kYAxis, 2);
		Cannon = new Victor(3);
		CannonHeight = new Victor(4);
		CannonDirection = new Victor(5);
		CannonFeedOut = new Solenoid(1);
		CannonFeedIn = new Solenoid(2);
		BridgeArm = new Solenoid(3);
		HeightUp = new DigitalInput(1);
		HeightDown = new DigitalInput(2);
		LeftKaren = new DigitalInput(3);
		RightKaren = new DigitalInput(4);
		AutoSwitch1 = new DigitalInput(5);
		AutoSwitch2 = new DigitalInput(6);
		AutoSwitch3 = new DigitalInput(7);
		WallDistance = new Ultrasonic(8,9);
		ShooterAngle = new Gyro(1);
		compressor = new Compressor(10,1);
		timer = new Timer;
	void AutonomousContinuous(void)
		compressor->Start();
		Cannon->Set(CannonSpeed);
		//Varible Values
		dsLCD->Printf(DriverStationLCD::kUser_Line1, 1, "US: %4.1f",
				WallDistance->GetRangeInches()); // display the rangefinder
		dsLCD->Printf(DriverStationLCD::kUser_Line2, 1, "CannonSpeed: %4.1f",
				Cannon->Get()); // display the cannon speed
		dsLCD->Printf(DriverStationLCD::kUser_Line3, 1, "Gyro: %4.1f",
				ShooterAngle->GetAngle()); // display the cannon angle
		dsLCD->UpdateLCD();
		if (AutoSwitch1->Get() == 1 && AutoSwitch2->Get() == 1
				&& AutoSwitch3->Get() == 1)
			// this auto mode will be the right side (no movement) and will turn cannon left and shoot twice
			// and rotate back to 0 degrees.
			/*mti*/Cannon->Set(CSspeed1); // cannon speed for auto modes(1-3)
			if (ShooterAngle->GetAngle() < 14.5) //detect the cannon angle
				CannonDirection->Set(.25); // move the cannon
			else if (ShooterAngle->GetAngle()>15.5)
				CannonDirection->Set(-.25);
			else
				timer->Start();
				CannonDirection->Set(Stop);
				if (timer->Get() >= 1 && timer->Get() < 3) // shoot ball at 1 sec
					CannonFeedOut->Set(true);
					CannonFeedIn->Set(false);
				if (timer->Get() >= 3 && timer->Get() < 5) // prepare cannon for another ball
					CannonFeedOut->Set(false);
					CannonFeedIn->Set(true);
				if (timer->Get() >= 5 && timer->Get() < 7) // prepare cannon for another ball & teleop
				if (timer->Get() >= 7) // shoot 2nd ball at another 1 sec
	if(AutoSwitch1->Get() == 1 && AutoSwitch2->Get() == 1 && AutoSwitch3->Get() == 0)
		//this auto mode will shoot twice (no movement)
	if(AutoSwitch1->Get() == 1 && AutoSwitch2->Get() == 0 && AutoSwitch3->Get() == 0)
		// this auto mode will be the left side (no movement) and will turn cannon right and shoot twice
	if(AutoSwitch1->Get() == 0 && AutoSwitch2->Get() == 1 && AutoSwitch3->Get() == 1)
		// this auto mode will be the right side (with movement) and will turn cannon left and shoot twice
	if(AutoSwitch1->Get() == 0 && AutoSwitch2->Get() == 0 && AutoSwitch3->Get() == 1)
		//this auto mode will shoot twice (with movement)
	if(AutoSwitch1->Get() == 1 && AutoSwitch2->Get() == 0 && AutoSwitch3->Get() == 1)
		// this auto mode will be the left side (with movement) and will turn cannon right and shoot twice
	if(AutoSwitch1->Get() == 0 && AutoSwitch2->Get() == 1 && AutoSwitch3->Get() == 0)
		// this auto mode will move the robot back X distance from the wall
	if(AutoSwitch1->Get() == 0 && AutoSwitch2->Get() == 0 && AutoSwitch3->Get() == 0)
		// this won't be an auto mode, it will sit still and do nothing
void TeleopContinuous(void)
	//Varible Values
	dsLCD->Printf(DriverStationLCD::kUser_Line1, 1, "US: %4.1f", WallDistance->GetRangeInches()); // display the rangefinder
	dsLCD->Printf(DriverStationLCD::kUser_Line2, 1, "CannonSpeed: %4.1f", Cannon->Get()); // display the cannon speed
	dsLCD->Printf(DriverStationLCD::kUser_Line3, 1, "Gyro: %4.1f", ShooterAngle->GetAngle()); // display the cannon angle
	dsLCD->UpdateLCD();
	MyRobot->TankDrive(.25, .25); // create tank drive with the left & right stick
	Cannon->Set(CannonSpeed); //set the default cannon speed for teleop
	if(Xbox->GetRawButton(3)) // (button X) spinning lazy karen left
		CannonDirection->Set(1.0);
		if(LeftKaren->Get() == 1)
	else if(Xbox->GetRawButton(2)) // (button b) spinning lazy karen left
		CannonDirection->Set(-1.0);
		if(RightKaren->Get() == 1)
	else // do not rotate if buttons are not pushed
		CannonDirection->Set(0);
	if(Xbox->GetRawButton(4)) // (button y) raise height
		CannonHeight->Set(1.0);
		if(HeightUp->Get() == 1)
			CannonHeight->Set(Stop);
	else if(Xbox->GetRawButton(1)) // (button a) lowering height
		CannonHeight->Set(-1.0);
		if(HeightDown->Get() == 1)
	else // stop cannon height if no button is pushed
	if(Xbox->GetRawButton(6)) // speed up the cannonspeed
		CannonSpeed+=.01;
		if(CannonSpeed>=1)
			CannonSpeed=1;
	else if(Xbox->GetRawButton(5)) // lower the cannonspeed
		CannonSpeed-=.01;
		if(CannonSpeed<0.25)
			CannonSpeed=0.25;
	else if (Xbox->GetRawButton(10))
		CannonSpeed=.5;
	if(Xbox->GetTwist()> .5) // shoot ball when bumber is pushed in
	else // when bumper is released reverse action
	if(Xbox->GetTwist() < -.5) // when the other bumber is pushed deploy the bridge arm
		BridgeArm->Set(true);
	else // when the bumper is released reverse action
		BridgeArm->Set(false);
void DisabledPeriodic(void)
	//		GetWatchdog().Feed(); // feed the user watchdog at every period when disabled
void TeleopPeriodic(void)
	//		GetWatchdog().Feed(); // feed the user watchdog at every period when in autonomous
void DisabledContinuous(void)
void AutonomousPeriodic(void)
/********************************** Init Routines *************************************/
void DisabledInit(void)
	DriveLeft->SetSafetyEnabled(false);
	DriveRight->SetSafetyEnabled(false);
	Cannon->SetSafetyEnabled(false);
	CannonHeight->SetSafetyEnabled(false);
	CannonDirection->SetSafetyEnabled(false);
	MyRobot->SetSafetyEnabled(false);
	ShooterAngle->Reset();
void AutonomousInit(void)
void TeleopInit(void)
void RobotInit(void)
	// Create and set up a camera instance. First wait for the camera to start
	// if the robot was just powered on. This gives the camera time to boot.
	 AxisCamera &camera = AxisCamera::GetInstance();
	 camera.WriteResolution(AxisCamera::kResolution_320x240);
	 camera.WriteCompression(60);
	 camera.WriteBrightness(0);
	// set up gyro
	ShooterAngle->SetSensitivity(.01); //change later to a  diffrent sensitvity
	MyRobot->SetExpiration(20.0);
	MyRobot->SetSafetyEnabled(true);
START_ROBOT_CLASS(ArmyOfSumRobot)
Unread 14-02-2012, 14:53
dcherba dcherba is offline
FRC #3234 (Red Arrow Robotics)
dcherba has a spectacular aura aboutdcherba has a spectacular aura aboutdcherba has a spectacular aura about
Re: C++ MotorSafetyHelper
For every motor in the telop period and autonomous period you must make sure to use the set function for every motor. This insures that the motor is under control. If it does not receive a set frequently enough acts like a watchdog timer event.
Dave Cherba
Mentor Team 3234
WZ8T
Unread 14-02-2012, 17:34
Originally Posted by Team2246 View Post
Hello,
The MotorSafetyHelper is not new, it was added last year. What is new is it sending messages back to the Driver station in C++ and Java. Last year it only did so in LabVIEW.
