#8
Re: 1 Motor in LabVIEW?
Check your PWM cable polarity.
Try switching the PWM cable from one of the working Jaguars to the blinking one to see if it gets signal and goes solid. As long as the code performs an Open for the Jag, then the Jag light should be solid when the robot is Enabled. |
