Go to Post Given the time Banebots has already cost us, what's a little snow? - pfreivald [more]
Unread 14-02-2012, 16:17
SmurfinLennon's Avatar
SmurfinLennon SmurfinLennon is offline
AKA: Sabrina
FRC #1676 (Pascack Pi-oneers)
Team Role: Animator
SmurfinLennon is a glorious beacon of lightSmurfinLennon is a glorious beacon of lightSmurfinLennon is a glorious beacon of lightSmurfinLennon is a glorious beacon of lightSmurfinLennon is a glorious beacon of lightSmurfinLennon is a glorious beacon of light
Re: Help with making the Iiko walk in Maya?
My team used a reference picture like http://bobbypontillas.com/blogpics/walkplan.jpg to make a walk cycle, which would be 24 frames (24 frames/sec.) that when repeated creates a smooth walk.
The picture is really helpful because it shows you the positions the legs should be in at each frame. All you do is go to the frame, position the legs, make a keyframe and go on and do the same for the next. This should create smooth transitions between each leg position.
Sabrina C.
Team 1676 Pascack Pi-oneers
Unread 19-02-2012, 14:18
suzumebachi's Avatar
suzumebachi suzumebachi is offline
Dream FIRST
AKA: Giselle
FRC #0178 (2nd Law Enforcers)
suzumebachi is on a distinguished road
Is there a skeleton/rig setup for the iiko in Maya? Last year we used 3ds max and used it pre-rigged, but this year the team decided to switch to Maya.
Unread 19-02-2012, 17:25
SCRktkt SCRktkt is offline
SCRktkt is an unknown quantity at this point
There is a rig that comes with it; alternately, you could make one and skin it.
Adam Crespi
Autodesk Certification Evaluator
Instructor, The Art Institute of Seattle
Unread 20-02-2012, 14:00
Dream FIRST
AKA: Giselle
How do you...get to the rig?
Unread 20-02-2012, 15:37
AKA: Sabrina
Team Role: Animator
http://curriculum.autodesk.com/stude.../project_id/34
On that page at the top, the red button that says "3D files" will open a window with different files to download, one of them is the maya rig
Sabrina C.
Unread 13-03-2012, 08:32
ajc4nn0n's Avatar
ajc4nn0n ajc4nn0n is offline
FRC #0011
ajc4nn0n is an unknown quantity at this point
I figured out the walk cycle but now my iiko is white instead of the normal color and the body doesn't show up in render view. Does anybody know why this happens?
