Re: 1 Motor in LabVIEW?
Your Begin looks like it's opening the motor correctly, so the speed controller's LED should stop blinking when the robot is enabled. If it doesn't, there's mostly likely a wiring problem (or a broken component). But make sure you aren't still getting any errors on the Diagnostics tab of the Driver Station.
Try swapping the PWM cables between one of the Jaguars that works and the one that doesn't. If the problem follows the cable, focus on the Digital Sidecar connection. If the problem stays with the Jaguar, mark it as suspect and replace it. |
I've tried ALL of the above, except the "Replacing the Jaguar."
If you can decypher this: I took the PWM Cable off of one of our Drive Jaguars (we'll call it Jaguar 1) and swapped it with the PWM Cable off of the Single Motor (Jaguar and PWM 5, respectively), thus making the 5th Jaguar act as PWM 1, and the 1st Jaguar act as PWM 5. This caused Jag5 to turn solid yellow when enabled and Jag1 to blink constant yellow. So it has to be somewhere in the cRIO, Programming, Code, or Wiring. I have followed the above diagrams to the very last detail, only differing on the name. Hopefully, someone can figure out our problem. |
What is the Robot Singal Light doing? Do you have a good 12 volt power connection to your Digital Sidecar? Are all three of the power LEDs on the DS brightly lit? If the first four PWM outputs work but no more, that's a common symptom of a DS that's starved for power.
This is another issue our team experienced. First, we tried swapping out cables which connected the cRIO to the Digital Sidecar. When this failed, we opened the sidecar and saw an alarming burn mark next to the PWM channels which weren't working. Metal filings made their way into the sidecar. I'd check your sidecar for this issue.
