Go to Post Not only would it be cool but the mental image of Dave's suffering when he writes a message in unintelligible characters makes me grin uncontrollably. - Andrew Schreiber [more]
Unread 14-02-2012, 16:33
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Outputting to Smart Dashboard
We are using netbeans and we have the output to the built in compiler on netbeans, but we can't get the output to display on the smartdashboard, any help would be greatly appreciated! If you give us basic code for outputting to the smart dashboard that would be even better
Unread 14-02-2012, 17:29
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: Outputting to Smart Dashboard
SmartDashboard.putData("name", 123)
Is enough to send data. On the dashboard side you should see a field named "name" show up. You can then choose to format it as anything you want.
It's helpful to add a connection indicator to the SDB so you know when its connected.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 14-02-2012, 17:48
ksafin's Avatar
AKA: Kirill Safin
Thanks, that makes sense. However, how do I get the "name", I do not see it on the Driver Station, unless this is not what you meant by the "dashboard side".
And after looking at the constructor, I am still confused as to what a "key" is. Also, what does the 123 in your code signify?
Thanks again!
Unread 14-02-2012, 17:57
Do you have the SmartDashboard running? The SmartDashboard is not the default dashboard or driver station. You can get it here. It's intended to be a replacement for the default dashboard, and easier to customize.
The SmartDashboard displays data based on the key of the data. The first parameter of putData is the key, the second is the data. If I wrote putData("Gyro Heading", gyro.getAngle());, a field would be created called "Gyro Heading" with the current value of the gyro. Subsequent calls to putData with the key "Gyro Heading" would update the same field instead of creating a new one.
The 123 was just a sample value to send.
tough.exit();
Unread 14-02-2012, 18:17
ksafin's Avatar
AKA: Kirill Safin
Alright thanks, I had downloaded the file previously, but I was confused why it was merely blank when I ran it. It makes sense now.
Now, do you have any idea how I would go about putting the camera feed from the default dashboard onto this Smart Dashboard?
Thanks so much!
Unread 14-02-2012, 18:40
Thundrio Thundrio is offline
Dedicated Racer
FRC #3673
Thundrio is on a distinguished road
I believe there is an option to add a camera widget on the top of the SmartDashboard. its under add->.
granted i havent got smartdashboard to connect, so idk if it works.
Interested in a new way of playing old games?
visit http://www.speedrunslive.com for a way to make single player games multiplayer!
visit http://www.zeldaspeedruns.com to open up a new world for zelda lovers!
pm me here or at zsr for more information!
Unread 16-02-2012, 14:03
mv2112's Avatar
mv2112 mv2112 is offline
Derpologist
AKA: Mike
FRC #3044 (0xBE4)
mv2112 is an unknown quantity at this point
Hey im kinda new to the SmartDashboard. Is it legal to use in competition?
Unread 16-02-2012, 14:51
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
Absolutely. Any dashboard is. It's the Driver Station that cannot be changed.
Unread 16-02-2012, 16:37
AKA: Brad
#0190 ( Gompei and the Herd)
It's legal and uses TCP/IP port 1735 which has been opened this year in the field management system.
Brad
Brad Miller
Robotics Resource Center
