Go to Post it takes a village to raise a robot. - Taylor [more]
Unread 14-02-2012, 17:52
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Team Update 2012-02-14
GAME
General Announcements
Kinect Kiosk Software
A new version of the Kinect Kiosk software has been posted. It enables multiple machines on the network to have the Kinect Server running as long as only one is actively using the Kinect. This would be potentially necessary for the Kiosk to function properly at pre-ship events if multiple teams have the Kinect software setup.
Scoring
[G40]
The Answer in the Q&A to the Question asked on Rule [G40] by FRC2826 on 01/17/2012 has been updated. We apologize for the confusion.
Power Distribution
[R43]
Please note, per [R64] [R63], that for an 8-slot cRIO, the circuit may not exceed 16W. For a 4-slot cRIO, the circuit may not exceed 21W.
Smaller value Snap Action auto resetting breakers may be used on the PD Board for circuitry not defined above.
In addition to the required branch power circuit breakers, smaller value fuses or breakers may be incorporated into custom circuits for additional protection.
Motors & Actuators
[R48]
Note that this is not a change to the Rule but is simply changing the Rule to match the documentation (Kickoff Kit Checklist and FIRST Choice site).
The only motors and actuators permitted on 2012 FRC Robots include:
up to 2 Denso throttle control motors (acceptable part # AE2351000 AE235100-0160)
The code box is the blue box. (And bolded stuff is what was changed, idk how to cross things out)
The Q&A update redefines the Bridge, the ball ramp no longer counts as part of the bridge.
Question:
Q. What physical parts make up the bridge by definition? Essentially, where does the bridge begin and end? For example, does the welded structure under the bridge that the top connects to count as the bridge? Does the lateral bar that rotates with the bridge that count as the bridge?
Revised answer:
A. The Bridge is defined as all components depicted in GE-12017, with the exception of the Bridge Base (GE-12022) and the Ball Ramps (GE-12064). Updated per Team Update 2012-02-14.
Last edited by Steven Donow : 14-02-2012 at 17:55. Reason: added question and formatting
Unread 14-02-2012, 18:50
Chris is me's Avatar
AKA: Pinecone
Re: Team Update 2012-02-14
This is week 6 and they redefined a fundamental part of the game, impacting multiple teams' well thought out and carefully crafted designs. I'm far too frustrated to say more right now.
Unread 14-02-2012, 19:10
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
A couple of years ago they did it after week 1 events
___________________
- Tennyson, Ulysses
Unread 14-02-2012, 19:22
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
This was obviously a strategy that was never going to be allowed. Nevertheless they should have been more careful with their definition of bridge.
This is better than 07 when 111 asked if you could stack robots pre-match for points and the gdc said yes then turned around and made it illegal during the season.
2001-2004: Team 100
2006-Present: Team 254
Unread 14-02-2012, 19:25
Aren_Hill's Avatar
Build Nifty Things
If they respond twice, to two questions asking for the definition of bridge, with an answer that defines that ramp as part of the bridge, on a QnA forum defined as official interpretation, why wouldn't it be allowed?
A guy who likes robots.
Unread 14-02-2012, 19:26
GW Kalrod GW Kalrod is offline
AKA: Nick Plante
FRC #0166 (Chop Shop)
GW Kalrod is an unknown quantity at this point
Send a message via AIM to GW Kalrod
Anytime you go for a strategy that everyone is aware is essentially a loophole based on rules, you risk the rules changing and being out of luck.
KISS (otherwise known as the easiest way to not win.)
Unread 14-02-2012, 19:39
Cory's Avatar
AKA: Cory McBride
Because the intent is clearly to be on top the bridge. If they dont want people hanging from the bridge why would they want you to drive under it to balance?
Its obviously a loophole that they mistakenly opened with their Q&A response.
Obviously you shouldnt have to judge intent and the Q&A needs massive improvement but nobody should be surprised at this update.
2001-2004: Team 100
Unread 14-02-2012, 19:53
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
We are given a definition. We design around that definition. The definition changes but the deadlines don't. Sounds kind of like engineering...
Ok, in the future I will push my team's designs away from being creative and no more thinking outside the box.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 14-02-2012, 19:58
AKA: Nick Plante
Not the purpose at all, look at the breakaway finals. You just have to be prepared for rule changes.
Unread 14-02-2012, 20:01
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Remember when people were honestly surprised that they weren't allowed to launch the minibots up the pole? And then they designed an elegant solution that did precisely that without doing that?
Hi!
Unread 14-02-2012, 20:05
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Part of engineering is anticipating what your customers want. Ever worked a project before it's fully funded? I have, and it was because if I didn't I wouldn't have met the schedule expectations. How creative teams get with that anticipation is 100% on the teams.
If FRC were the open marketplace, the GDC basically just said customers aren't going to buy cute little troll bots with pink hair. If this were the government or a large company who put out an interactive RFP, this is like them saying "that's not what we meant". And "that's not what we meant" was almost a weekly occurrence on some of my projects.
So Swamp Thing -- does your bot still comply? I'm not sure what all encompasses the "Bridge Base", but from a first look it still does.
GitHub
Unread 14-02-2012, 20:12
Based on this statement, do you think that 179's robot will soon be illegal, also?
Unread 14-02-2012, 20:27
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
We only touch the top of the bridge, so this has no impact to our strategy. However we were ready to troll if necessary...
www.179swampthing.org
Unread 14-02-2012, 20:29
Andrew Lawrence
Posts: n/a
No, since it's still supported 100% by the bridge. It is still touching the bridge part itself, and no other part of it. If what 179 did turns our illegal, I'm sending an angry email to FIRST, with a bunch of frowny faces.
Unread 14-02-2012, 21:06
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
bad plan this trolling will only get you penalties and stop your team from getting balancing points D:
cole?
