My team is having difficulty with the FRC crio II that we purchased recently. i followed the getting started guide and tried a few suggestions on CD (crio not in safe mode, ip is correct) but have not been able to get the crio imaging tool to find the crio. i have checked and have both the labview and ultilities updates installed. The setup worked with the 8-slot crio that we have right now but we wont be able to use it for competition. The 4-slot crio is out of the box with no settings changed so what steps do i need to take to get the crio to be reconized by the imaging tool and the driverstation?
Thanks in Advance Jon Last edited by bladetech932 : 14-02-2012 at 19:06. |
Re: crio setup
Is your windows firewall turned off? What is the laptop's IP address?
Re: crio setup
yes the firewall is off. i have tried 10.9.32.1,10.9.32.2,10.9.32.5,10.9.32.6
Re: crio setup
Try 10.9.32.51 also make sure you have it tethered via the ethernet crossover cable.
Re: crio setup
Some things to try:
Re: crio setup
Also make sure you are not using last years imaging tool.. if you're using a laptop with software from previous years. That would work with the old cRio but not the new one (I think). The new one is labeled "FRC 2012 Imaging Tool".
