Go to Post We want to go out and build something right away. But it is better to think a little bit first. - ChrisH [more]
Unread 13-02-2012, 17:23
Iron Drakes Iron Drakes is offline
FRC #4181
Iron Drakes is an unknown quantity at this point
Programming Question
How do we resolve the following problem:
"output not updated often enough"
We are trying to write a couple of simple programs. We want our left joystick buttons "trigger" and "2" to start and stop a motor hooked to a jaguar in pwm 5. Any insight you can provide would be great.
Unread 14-02-2012, 19:06
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
Re: Programming Question
I'm assuming you're using Netbeans. And without the code that's glitching, it'd be really hard to help you fix yours. CD could post examples, but not actaul advice. If you can isolate and post the glitchy section of the code, it'd probably help.
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
