Go to Post It’s possible to make friends without agreeing on everything. - Bill Gold [more]
Unread 14-02-2012, 19:18
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
Question Open text file
One of my teammates is trying to open a text file(.txt) on the robot. We not have found the correct methods.
Please respond! Thank you.
Off to WPI!
Go OxBE4
Unread 14-02-2012, 22:19
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
Re: Open text file
There is a class called InputStreamReader available in Java ME (robot version) that can read from a file. If you search for InputStreamReader on the internet, you will find some examples of how to use it.
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
Unread 14-02-2012, 23:31
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Re: Open text file
YuP
Unread 15-02-2012, 00:06
TravSatEE's Avatar
TravSatEE TravSatEE is offline
Spacecraft Engineer and more
FRC #2035 (Robo Rockin' Bots)
TravSatEE is infamous around these partsTravSatEE is infamous around these parts
Re: Open text file
The best overview of the file read/write code I have seen is available in [1] around slide 7 with example code.
[1] http://www.usfirst.org/uploadedFiles...FRCKickoff.pdf
Unread 15-02-2012, 18:12
Herbblood's Avatar
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Exclamation Re: Open text file
Okay i got the FileConnection file = (FileConnection) it says unreported exception java.io.IOException must be caught or declared to be thrown,and when i do the try catch if still says that.
As well as i can't(when it is put as FileConnectionfile = new File Connection() is says that the sunsquack is abstract and cannot be instantiated.
Any ideas as what to do please?
If anyone has actual code to open a (.txt) file on netbeans it would be deeply apprectiated!
Thank you.
Off to WPI!
Go OxBE4
Unread 15-02-2012, 20:15
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
Question Re: Open text file
we've looked at that, but we are still having issues. we want to open a text file that has a large number of double numbers seperated by newlines. the totoral posted are more directed at outputting(which is nice though) any other totorals or sites?
ty all in advance
"you can build a perfect machine out of imperfect parts" -Urza
Unread 16-02-2012, 16:57
ItzWarty ItzWarty is offline
FRC #1072 (Harker Robotics)
ItzWarty is an unknown quantity at this point
Re: Open text file
This interface is implemented on our version of Java:
http://developers.sun.com/mobility/a...ileconnection/
I'd assume that they wouldn't reinvent the wheel (or in this case, the API)
I've used that API for TCP Sockets
Leader of Team 1072. Software developer of RAF Manager.
Follow me on Twitter: Twitter.com/ItzWarty/
Unread 17-02-2012, 16:15
techkid86's Avatar
Magic Programer
FRC #3044 (0xBE4)
we has this as code, but it only reads every other character.
ex.
in text file: 1234.5678
reads out: 2457
i have checked the character encoding, and it seems to be in ASCII. but, the read char is in Unicode. so i outputed the raw bytes, and converted it into ASCII, and the output just was the ASCII reprisentation.
DataInputStream dataStream=new DataInputStream("file:///FTPtest.txt");
char[] c=new char[9];
for (int i=0;i<9;i++)
c[i]=dataStream.readChar();
System.out.println(new String(c));
any suggestions?
found it.... nvm.... *face palm*
Unread 17-02-2012, 20:44
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
Re: Open text file
this is how we have been able to open and read a text file which is terminated by a semi colon:
    private final String PATH = "file:///Sparx/mytxt.txt";
    private final char ESC_CHAR = ';';
try
                FileConnection read = (FileConnection) Connector.open(PATH, Connector.READ);
                fileRead =  read.openDataInputStream();
                String theString = "";
                while(true)
                    byte ch = fileRead.readByte();
                     if(ch == ESC_CHAR)
                        break;
                    theString += (char) ch;
