Go to Post but then again, isn't FIRST a sport? I mean come on now, our championship is nothing less than the super bowl. :) - Arefin Bari [more]
Unread 14-02-2012, 19:34
Rogue Leader Rogue Leader is offline
FRC #0696 (Circuit Breakers)
Rogue Leader is an unknown quantity at this point
Re: Simple Crosshair
Originally Posted by hsekhon27 View Post
After I create a dashboard project, how do I deploy it?
If I'm correct, you would open a program called the "FRC Driver's Station" once your computer is connected to the robot, Once that's open you would also launch a separate program called "FRC Dashboard," although I think the Driver's Station would open up both.Then launch the cRIO Robot Project, then deploy it (from RobotMain). You need to launch these in order to run the robot, so I hope I helped you in some way.
