Go to Post I have long since given up on these hints, and come to the conclusion that they are designed to befuddle us all and amuse Dave. - Rickertsen2 [more]
Unread 14-02-2012, 02:26
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Simple Crosshair
Hi I am a rookie programmer who barely started using labview. I basically finished all my controls including the kinect so I was wondering if it was possible to add a simple + crosshair to the video camera feed. I have the camera directly to the router not cRio. So is there a way I can do this without to much complication.
Unread 14-02-2012, 02:59
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Re: Simple Crosshair
The simple way is to place tape on on the screen. When you open the driver user, the drive station will default to the same place every time.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 14-02-2012, 03:07
FRC #4210
Is there a way I can program something..
Unread 14-02-2012, 07:54
The first step is to open the Getting Started Window of LabVIEW. It is up when you first launch and it is available from the View menu. Create a project based on the Dashboard template.
When built, that code will create the same thing as the initial installation.
There are a couple ways to add crosshairs. One, go to the panel, right click in open space and choose lines from the decoration palette.Place and size the lines, color them if you need to. You could use rectangles if you wanted thicker lines.
The second approach is to add the lines into the image programmatically. Go to the diagram and find the loop near the top that Reads the MJPG and the next step it does is clear the overlays. Instead, you want to right click on the Clear and choose Replace Overlay and choose the Line function. Copy it and hook up another. Hook up the parameter values to describe the line endpoints and color.
To test it, stop the other dashboard EXE and run your VI using the run arrow. To build it into an EXE, you go to the bottom of the project window, open the Build Specifications, and right click and Build. The resulting dialog will tell you where the EXE was saved. Copy it to the Program Files/FRC Driver Station folder and you are good to go. The DS will launch yours next time it starts up.
Greg McKaskle
Unread 14-02-2012, 08:49
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Greg McKaskle
I did A similar technique last year.
what I did was I used the "draw rectangle" overlay block twice, one for each crosshair. I did it this way so I could adjust the thickness...
It also was linked to the tilt servo position so it would automatically rotate the image when the camera passed 90 degrees... it also changed the crosshairs to a set of parallel lines that could be used to line up with the minibot pole.
Unread 14-02-2012, 08:56
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
You know the Kinect is only used during the first 15 seconds of the match, correct? I apologize if that seems a silly question.
HTH
Unread 14-02-2012, 13:06
It does seem very silly. I think you posted in the wrong thread.
Unread 14-02-2012, 19:08
hsekhon27 hsekhon27 is offline
FRC #0280 (TNT)
hsekhon27 is an unknown quantity at this point
Greg McKaskle
After I create a dashboard project, how do I deploy it?
Unread 14-02-2012, 19:34
Rogue Leader Rogue Leader is offline
FRC #0696 (Circuit Breakers)
Rogue Leader is an unknown quantity at this point
If I'm correct, you would open a program called the "FRC Driver's Station" once your computer is connected to the robot, Once that's open you would also launch a separate program called "FRC Dashboard," although I think the Driver's Station would open up both.Then launch the cRIO Robot Project, then deploy it (from RobotMain). You need to launch these in order to run the robot, so I hope I helped you in some way.
Unread 14-02-2012, 21:01
From the Project Explorer window
Build Specifications -> FRC PC Dashboard right-click and choose Build
It's going to put the new Dashboard in the project folder under builds. Something like:
My Documents\LabVIEW Data\builds\FRC Dashboard Project\FRC PC Dashboard
You can test it by running it from there, but for competition it'll need to get copied to the folder C:\Program File\FRC Dashboard
There are several common variations:
  1. You can change the Destination Directory under Properties for the build specification. That will automatically put your Dashboard in the FRC Dashboard folder.
  2. You can change where the Driver Station looks for the Dashboard program. That's defined in an ASCII file located at: C:\Users\Public\Documents\FRC\FRC DS Data Storage.ini (shouldn't be edited while the Driver Station app is running).
Unread 14-02-2012, 21:28
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
MAldridge will become famous soon enoughMAldridge will become famous soon enough
assuming you do dev on a separate computer, you just need to copy the three files that the build will spit out into the dashboard folder on your driver station.
If memory servers, its just in the x86 programs folder.
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
Unread 14-02-2012, 22:58
FRC #0280 (TNT)
Thank you!!
Unread 22-02-2012, 23:07
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Is there a way to disable the snap-to-grid when drawing lines on the panel?
Unread 23-02-2012, 08:34
Hit the <g> key to toggle it
Greg McKaskle
Unread 23-02-2012, 11:04
CodeMonkey's Avatar
CodeMonkey CodeMonkey is offline
Self Proclaimed Ruler of Universe
AKA: Omar Issa Attar
FRC #0599 (Robodox)
CodeMonkey is an unknown quantity at this point
I was wondering, how did you get the lines to change from crosshairs to parallel.
